hi i have a nokia d box birmingham got channels on but yellow key locked ithnk stop me seeing channels apart from free view is there any body i could visit or pick up in birmingham could show how to correct this please some of the jargon a bit much for me but if showed would be ok . thanks all
nokia d box in birmingham
M8 i gave you a link in your other thread. Download a couple of guides from the downloads section and do it yourself. It's not really that hard. If your stuck after reading up just ask and someone will help you out.
The panel has quite simply found 'no evidence' in support of allegations of 'exceptional levels of drunkenness, ticketlessness or violence among Liverpool fans' and 'no evidence that fans had conspired to arrive late at the stadium' and 'no evidence that they stole from the dead and dying'. -
You can enter the codes in and that will clear all channels but it's only a temp fix. You really need to put the magic files in which are auto updating. If you want to change the keys manually for now then do the following. Taken from elsewhere...
. Press the blue button and you will be in the features menu, scroll to Tuxbox Commander, press OK.
You should now be looking at the files on the D Box.
. Scroll to VAR and press ok, If you don’t see VAR, scroll to <DIR> & press ok, if you still don’t see VAR scroll to the next <DIR> and press ok, keep doing this until VAR appears on the screen!
3
. When you find the VAR file and you press OK, scroll to Keys & press OK
4
. Scroll to Keylist.txt and press 4 on your remote control! It is important that you don’t press OK when you scroll to keylist.txt , you must press 4 in order to edit the code that will appear! If you pressed OK in error , just press the Home button and start again.
5.
After pressing 4 you should be looking at a screen with /var/keys/keylist.txt at the top, 4 or 5 codes in the middle and numbers 1 to 9 at the bottom.
6.
Now you need to scroll to the code that you are going to change, e.g old code is as follows:
N S401 00 587436A3B220CB46 and we need to change it to N S401 00 587436A3B230CB46
We are only changing one digit this time, in future you may have to change more digits.
7.
When you have have scrolled to code you want to change press OK, When you press OK, the code becomes slightly larger and the first digit changes colour to red, this is now your cursor!
8
. Scroll to the digit you want to change, and then use the numbers on your remote to change that digit to whatever character you want, e.g. if you want to change the digit to 3 , you press the number 3 button four times until 3 appears, the press ok. The same would apply if you want to change it to 4, you press the number 4 button on your remote four times and press OK.
9
. When you have changed the digit to the new one, press the Home button, it will ask you do you want to save changes, if you are happy with the new change, scroll to yes and press OK.
10
. You should now have changed the code, to get back to the TV screen, press home.
11
. In order for the changes to work you need to reboot, press the D box button and scroll to reboot and press OK. When it reboots you channels should be back!
