Problems with Flash FXP - Help?
  • hendinho
    • Aug 2008
    • 16
    #16
    Success!
    i can now connect to DBox using Flash FXP
    when transfering the keys and other things do i overwrite all
    • MetMan
      • 1091
      #17
      Originally posted by hendinho
      Success!
      i would save ur current img first - transfer to pc name and date it....dbox - service - backup / flash - backup 1 part partition - flash / back up without bootloader there will be a file mtd 3 or 4 in the tmp folder 7.88 mb thats ur img transfer to pc
      • hendinho
        • Aug 2008
        • 16
        #18
        Cheers for your help - i think i've taken enough of your time up for one niht so ill give the rest a go tomorrow night and see how i get.
        after saving the image is it then just a matter of overwrting the k*ys etc... and connectiong box up, leaving it on s*ysports1 for eg and restating the emu an waiting a few mins?
        • Fergal
          • Aug 2008
          • 1007
          #19
          Success!
          What did you have to change to get it to connect just incase anyone else has the same problem and reads this thread.
          just choose overwrite
          Yes
          • MetMan
            • 1091
            #20
            if ur happy with ur img just overwrite if u have the latest k*ey folder....save ur bouquet and service files found in ur var/tuxbox/config/zapit folder if u have scanned and sorted ur channels. if u have these files u can transfer them to any new img save u having to rescan and resort channels....
            • hendinho
              • Aug 2008
              • 16
              #21
              i just tried
              dbox 192.168.1.103
              gateway 192.168.1.1
              server 192.168.1.102
              again because i was trying to trace through the advise and all of a sudden it just connected - least to say i was shocked... thanks guys - ill let u know how it goes tomorrow night :S
              • dalcdog
                • 11
                #22
                Hi, i'm having a similair problem to hendinho (been trying all day grrr).
                I'm using FlashFXP and have tryed so many different combinations for the IP address i am muddled up.
                I have a wireless internet connection and a normal network card - which the dbox is plugged into.
                When i do ipconfig/all, i get this 192.168.2.2, default gateway and dns server 192.168.2.1, so i was just wandering if anyone can clarify what i enter in the debox settings. Also do i just leave the dbox on when i'm attempting to connect or do i need to keep unplugging etc?
                Any help would be muchos appreciated
                • Fergal
                  • Aug 2008
                  • 1007
                  #23
                  leave box on and crossover cable connected to box and pc
                  Press dbox,settings,network and see what the ip is then on your pc go to control panel,network connections right click on local are connection and pick properties click configure tab then look for flow control,duplex mode,media type it will be called one of those or something simular and set it to 10baseT_halfduplex or half mode then click ok you will then have to right click on local area connection again then hi lite internet protocol tcp/ip and click properties and give it a static ip one below the boxes ip subnet mask 255.255.255.0 click ok to close then finally right click on your wireless connection and disable it
                  example box if the boxes ip is 192.168.1.202 pc should be ip 192.168.1.201
                  there is a guide for flashfxp in the downloads aswell
                  once you have finished ftp'ing the box you will have to enable your wireless network to get on the net
                  • dalcdog
                    • 11
                    #24
                    thanks for the reply mate, I've sorted it by plugging it into my router with an ethernet cable and instant sucess! however can only get free to air channels, i've tried changing my location and just leaving it on sky sports but no luck.
                    I've installed the blade quad image, do i need to add keys or boquets or whatever?
                    • Fergal
                      • Aug 2008
                      • 1007
                      #25
                      Not to sure if it has check in var/keys for nagrarom7 also check that evocamd is selected in the dbox menu or the blue button menu somewhere
                      EDIT read this
                      • DiddyDave
                        • 213
                        #26
                        Right - i'm running Blade Quad 1x on a Sagem DBox2 (flashed okay)
                        Computer IP: 213.106.193.212
                        Router IP: 192.168.1.1 (found on a web site)
                        with DBox connected to the TV i went into Settings -> Network
                        and chaged the following
                        ip address to 213.106.193.213
                        default gateway to 192.168.1.1
                        dns server to 213.106.193.212
                        Then i connected dbox via ethernet cable to my router and turned it on
                        Ran Flash FXP
                        Try to connect to dbox by entering
                        IP: 212.106.193.213
                        Port: 21
                        User: root
                        Password: ive tried dbox and dbox2
                        and it wont connect so i can't transfer keys etc...
                        feeling helpless
                        Any ideas?
                        your ip addy is set to a public one you should be on the same range as the gateway
