DBOX2 Nokia in ExC&W
  • fazancrazy2004
    • 4
    Hiya Guys, I have got this box that has FTA channels and I have checked though the previous software installed on the box and it comes up with Sportser. I think.... I have downloaded FlashFXP and when I try to add the new Nagra Bin files and the new Image. the little screen at the bottom comes up as Failed to update. I just want to know, How do I remove the old software so I could install the new one. I have all of the EPG and current EMU settings I just want to know.. Is the box a gonna or could it saved by someone out there. Cheers Guys, Hoping to hear from you soon..
  • mini
    • 602
    What image have you got on?
    Are you ftp to the correct folder. It should be straight forward, you transfer nagra files to var\keys folder.
    • fazancrazy2004
      • 4
      Hey Buddy, I have the sporter software currently on the box. I did try try to drag and drop the new nagra onto the FTP software but no reponce, I just get a FAILED TO TRANSFER responce.
      Cheers
      • Fergal
        • Aug 2008
        • 1007
        Does it connect to the box ok also right click on the file and choose transfer see if it goes in then.
        • fazancrazy2004
          • 4
          I have setted up a connection to and from the box.. I can see the current files on the box but it does not let me delete the old stuff....
          • Fergal
            • Aug 2008
            • 1007
            Will it let you transfer files from the box to the pc?
            • bobsylas
              • 53
              Is the sportster image squashfs ? been a while since I had it on or may be it has gone read only, can you copy files to the /tmp folder ? if so you may need a reflash
              • fazancrazy2004
                • 4
                Hiya guys, the imagine is the sportster image squashfs, I cant access and delete nothing at all
                • Fergal
                  • Aug 2008
                  • 1007
                  It looks like its gone read only so you need o flash another image on you can use IFA or ftp the image to the /tmp folder then use the dbox menu's to flash it.
