hi guys put box on this morning all my channels r all over the place so flashed another image onto box all went well until the flashing had finished the box didant re boot so i did a forced reboot, since then all i get on lcd is kein system, how do i sort this, help,help,help,thanks guys....
box says kein system
You need to reflash it again using IFA
The panel has quite simply found 'no evidence' in support of allegations of 'exceptional levels of drunkenness, ticketlessness or violence among Liverpool fans' and 'no evidence that fans had conspired to arrive late at the stadium' and 'no evidence that they stole from the dead and dying'. -
hi m8 thanx for the reply, trouble is iam only used to using flash fxp, i have in the past tryed using ifa with no sucsess, do u know were i can get a good ifa prog from? cheers, chris..
A LITTLE THANX GOES A LONG WAY
Try this one- IFA Mobile, provided by Renwich. It works pretty well first time around 99.99% of the time,using Ethernet Cable only- the same one you use for FTP connection!
No install needed- it will even work straight from a USB Stick!
Cheers- AL
ps to DevilFish: this should be in Downloads, m8- but I'm ~~~~ed if I can see it...
Attached FilesComment
re ifa
hi m8 could u give me a quick run down on how to use this version of ifa coz as i mentiond before iam no good with ifa thanks chris..
