hi guys great image but how do you lock the naughty channels in ultra phat
ultra phat locking bouquets
This is LraiZer's original UltraPhat 1.0 image. Go to the same place you downloaded it from, where you should now find UltraPhat Apocalyse 1.1
This contains the latest zapit by Cydine, which is fixed for the new Channel Mapping (but still works fine if your area isn't yet on the new Map).
It also has the Adult Bouquet locked and hidden by default.
Cheers- AL
to clear this up, the only current ultraphat image in dbox2 downloads on this forum IS UltraPhat Apocalypse (nextgeneration) 1.1
after a "Create New Sorted" scan, "Adult" bouquet will be auto-hidden along with "Others" bouquet. "Adult" bouquet will also be auto-lock-enabled, however channels in the "Adult" bouquet WILL still be viewable UNTIL you turn on Youth Protection in your settings. once you have activated youth protection on locked bouquets, you will be prompted for your PIN when you attempt to view these channels.
Settings > Youth protection
set prompt for PIN setting to "on locked bouquets"
set change PIN code from "0000" to whatever you wantComment
Lol! I still think my way is best, no matter which image, on the lounge and bedroom dboxes (where the Grandaughter is likely to view).
1. Delete Adult Bouquet
2. Settings > Misc > Zapit Config > Show Unsorted Bouquet? OFF
Sorted, job done, no pr0n on box, full stop!! Cheers- AL
