sagem dbox2 1 chip or 2 chip
  • mdt
    • 3034
    im trying to sort a friends sagem dbox2 out but need to know if its 1 chip or 2. ive took the lid off and there is 1 large chip which says, avia@tv avia-600l but there is also a small avia chip near it under the the tuner which says avia@tv, avia.nx so is it a 1 chip or a 2. the image on it is blade quad which doesnt have set your location or uk bruteforce scanning. has anyone an idea of which type it is please and can somebody recommend a good img for use in bolton. thanks as always, regards mdt
  • plasterer
    • 1631
    You could always transfer a new cables xml to it ..............Paul
    PAUL
    • grahamera
      • Apr 2010
      • 4
      Those are not the flash chips. These or it is a lot smaller & more oblong. The word flash will be stamped on them or it along with the manufacturers name. These are usually intel but not always. I am using an modified sportster image which is stable.
      • mdt
        • 3034
        thanks for your reply m8, ive found it now. its a 1xchip version which says intel and flash on it. regards mdt
        • mickydibble
          • 2166
          its a 1x image then ,flsh one that is 1x,then add the magics,and chmod if you have to....m
