Dbox2 help
  • babalon23
    • Oct 2008
    • 25
    Dbox2 help
    Yeah the usual please help,I have a nokia dbox2 with commando 810 image on it always been temperamental have not used it since last year. If I download the new 9.25 image will it work people talk about keys and cams what are these and do I need them. Last time I just loaded the image and did a service scan.
  • cgscott
    • 3513
    Yes you need keys not sure what cams you get with the image but id download the new image my man.
    What probs you having with the image you got?
    Patience is a virtue.
    • plasterer
      • 1631
      No Team Commando images after comm 6 i think
      Will Have Cams or Keys included
      Try Blade Quad mate
      I beleive this comes Fully Loaded
      Just Flash and scan ......Paul
      PAUL
      • babalon23
        • Oct 2008
        • 25
        [QUOTE=cgscott;50942]Yes you need keys not sure what cams you get with the image but id download the new image my man.
        Thanks for the reply all the channels come up when I do a service scan but non of them decode, I have moved still in same city but the channels are not unlocking in my new place. Going to load the new com image, but I believe this dose not come with any keys. Have read a bit more on what to do, last time just loaded the image and sort of worked. What would you recommend.
        • babalon23
          • Oct 2008
          • 25
          The quad blade image on this forum has not got any key or cams as per forum rules where can I get a fully loaded copy so I can load and scan
          • MetMan
            • 1091
            [quote=babalon23;52145]
            your old commando will not work even if u hadn't moved....in april this year the cable companies changed the method of rolling (updating) the keys, your img from a year ago will not have files which will handle the new method....u can add one file to ur key folder and ur old img should update....the file is available on the net and is called nagrarom7 dated 08/04/2008
            cheers
            • babalon23
              • Oct 2008
              • 25
              [quote=MetMan;52151]
              Originally posted by babalon23
              your old commander will not work even if u hadn't moved....in april this year the cable companies changed the method of rolling (updating) the keys, your img from a year ago will not have files which will handle the new method....u can add one file to ur key folder and ur old img should update....the file is available on the net and is called nagrarom7 dated 08/04/2008
              cheers
              Thanks do I load this in var/keys folder, is nagrarom 10 better or not the same.
              • plasterer
                • 1631
                Nag 10 is not the same
                At the mo the rolling rom is Nagrarom 7
                Ftp this to var/keys Job Done .....Paul
                PAUL
                • cgscott
                  • 3513
                  Copy evrything from this site into the folders specified and you shouldnt have a problem.
                  Have a look at other people with the dbox's and check out what theyve achieved.
                  • babalon23
                    • Oct 2008
                    • 25
                    Hey dudes thanks for your help, I have tried the dbox 2 flashing assistant cant get it to flash. Will try the ftp next have ngr7 and com 925. Will see what happens.
                    • babalon23
                      • Oct 2008
                      • 25
                      Both dboxs keep coming up with connection refused any ideas
                      • cgscott
                        • 3513
                        Restart them. Switch off for a few seconds then reboot.
                        • babalon23
                          • Oct 2008
                          • 25
                          would norton antivirus stop it
                          • plasterer
                            • 1631
                            Yes it has been known
                            It needs to be Uninstalled ,If its that thats stopping it .....Paul
                            PAUL
                            • cgscott
                              • 3513
                              You can go into the settings on norton and disable the problem,
                              Unless u want to unistall.
