Bouquets??
  • Sparkyheaven
    Bouquets??
    Could somebody tell me what the difference is between a service.xml file and bouquets.xml file is??
    Im having trouble with my dbox2 got no channels after somehow deleting these files!! ive managed to download a services.xml file and transfer it to my box but still geting no channels!! should i have a bouquets file too and if so where can i download one from??
  • Jaffa
    • 1612
    Service file will have all the channel frequencies etc and bouquets files and just like folders, so if you had a bouquet called movies you would put all you movies chanels in that bouquets just to make it easier for yourself. Not having a bouquet file will have no affect on you not getting the channels.
    The problem lies elsewhere, maybe you need to put the keys folder in the image. Have a look in link below for services and bouquet files, there may be one for your area.
    • MetMan
      • 1091
      service file is formed after a scan or transferred into the var/tuxbox/config/zapit folder and should contain all the channels streamed through the cable listed in groups under each transponder frequency.
      a bouquet can be created to list the channels as u want or several bouquets can be created to group channels eg. movies sport etc.....a service file alone should show u channels
      • plasterer
        • 1631
        Wot area you in mate
        Wot image as Nutrino and enigma have differant locations .....Paul
        PAUL
        • Sparkyheaven
          Im in staffordshire area and im using sportser 1.73 image. Ive transfered the services.xml file for my area to /vars/tuxbox/config/zapit but everytime i power up my box i get the message
          "No channels were found.Please copy your services.xml and bouquets.xml or excute a scan using 1.73 ultra mode"
          Ive done scan using 1.73 ultra mode and copyed serivces.xml file but still no joy!!!
          • Devilfish
            Administrator
            • Feb 2008
            • 7872
            Copy the services.xml file to /var/tuxbox/config/zapit then do the following on the remote:
            DBOX > SERVICE MENU > RELOAD CHANNELS
            If that doesn't work, the services.xml file might not be suitable for your area.
            Do:
            DBOX > SERVICE MENU > SERVICE SCAN
            Make sure it says CableSym6952 (if you are in an ex-tw area) or CableSym6887 (if you are in an ex-ntl area). If you're not sure what area you're in, and the image has a bruteforce option, use that. Once you select that, hit START SCAN.
            Then go and run a bath, make a cup of tea, walk the dog, and when you get back, it might have finished the scan. These old images take ages to scan.
            • plasterer
              • 1631
              Just reflash with Blade quad mate
              Push blue on remote
              Set your location and enter your fast scan id .......paul
              PAUL
              • Sparkyheaven
                Just tried reload the channels option and tried doing many different scans (the symbol rate is correct 6.887) and still no joy.
                Dont really want to try different image as ive never flashed one yet im still learnig!! . Had my box fair few years and had very few problems with it, lost contact with the guy who did it for me tho so having to learn from scratch!!!
                when i do a scan its picking up transponders (13 of them) but doesnt seem to locate any channels?
                And if i do change the image where can i get the blad quad image from??
                • MetMan
                  • 1091
                  have u set the frequency to 826250 and net id to 00015?
                  • Sparkyheaven
                    Just tried another scan for "all services" instead of scanning for just Tv & Radio and its found 57 transponders!! Ive now got my channels back along with radio stations so thanx for the help peeps!!! YEY.
                    Just one last question tho i noticed when it was doing the scan it was scanning for tv radio and data, what is the data??
                    • resound
                      • Apr 2009
                      hi can some1 please send me bouquets files for s. london, i cant download files cos I've just registered. Thx!
