Dbox2 Flashing Assistant
  • harry1986
    • 516
    Has anyone got the english version of Dbox2 Flashing Assistant?
  • peco
    • 165
    IFA V3 is in English
    Although the writing is in German you have the multi language option during install.
    • drinking_eyez
      any step by step guide to flash nokia dbox2 from the scratch? coz I am newbie in this tech and my nokia dbox2 says "Waiting for Timing" all the time...
      • tid
        • 4
        Hey driniking_eyez,
        You need a serial cable and a cross over cable.
        All the guides you need are in the downloads section:
        Digital Kaos - Downloads - Guides
        tid
        • PaphosAL
          Old Git
          • 1064
          Better still, try IFA 3.1 Portable, thanks to our good fiend Renwich. All in English- and the first IFA I've ever tried where you DON'T need a null-modem cable.
          It's a standalone, too- will work from a USB Stick drive! Works great for me, even when AVG 8 is active.
          Cheers- AL
          • harry1986
            • 516
            thanks all sorted thankyou for all your help
            • mediya
              • 15
              I'm complete newbie here .... I'm trying to flash by dbox2 but. I tried to download the guide to flash but wouldn't let download .. do you guys know why ??
              • gizmo.1484
                • 873
                Give it 15 mins for server to update then you will be able to d/load .
                Have a look about in the mean time plenty to learn on the dbox..
                • mediya
                  • 15
                  hi gizmo
                  thanks .... ya i've managed to download the guide ... but I still cant flash the box after going thru' the guide ...
                  This is what I'm trying to to ....
                  I've connected the dbox with rj45 (network cable) and connected one end of a null modem cable to dbox and the other end to a 'RS232 to USB' cable and connected the USB end of the 'RS232 to USB' to the PC and I've disabled all the firewalls.
                  I executed IFA 3.2.1 and it asked for the image which I selected (Commando_10cR_x2_20-12-2008_20h07.img) then selected the network card and on Step 3 where it asks whether you have a 'Null mobem cable' I clicked 'Yes' and for the port it only gives me com port 1 on the dropdown. so I selected that ... finally I clicked start button and all it says is 'waiting for Dbox to start' ... I've already started dbox but its not doing anything ... i've left for about 10 mins and its not doing anything ...
                  Ohh by the way I had an old image on the box already ... do I need to remove that Image from the box before I install the new image ??
                  hope you guys can help me ... I'm a complete newbie and I've never flashed a box before. so pls pls help me.
                  • Salami
                    • 535
                    hi gizmo
                    You have done everything correctly you are not too far away from flashing the new image.
                    once all the cables connected start IFA and do exactly what you said above then connect the power cable to Dbox and you will see that image flashing lines on your PC or Laptop monitor.
                    Good Luck.
                    If you like my post pleas click on the little button to say thank you.
                    • mediya
                      • 15
                      Good Luck.
                      thanks a lot salami I managed to flash the box ... but where do I go from there ... do I just plug it in now or do I need to FTP any files before I restart ?? can you pls let me know ... I would be much appreciated if you could tell me how to do it step by step ....
                      TIA
                      • StephenDon24
                        • Jun 2009
                        Been looking for this - many thanks!
                        • mediya
                          • 15
                          can someone help me to get my box up and running pls ... I've flashed my box but dont know where to go from there ... pls help me as i'm eagerly waiting for a response.
                          TIA
                          • plasterer
                            • 1631
                            Wot image is on it now
                            Just push blue on remote
                            Select your location
                            Reboot and rescan .....................Paul
                            PAUL
                            • mediya
                              • 15
                              thanks for your reply the Image I have is Commando 10 .. sorry I pushed the blue button but I couldn't find any place where I could set the location .. I'm in birmingham area how to set the location .... can u explain that in detail for me pls ... dont I need to copy any files after flashing ?
