No epg?
  • harry1986
    • 516
    No epg?
    ok i put all the keys in the right place and found all the channels but they all are blank im using dbox2 i pressed the ? button on the sky sports channel and waited and nothing came up all it says is no epg and at the bottom it says waiting for time? I Just get the Bbc Channel
  • thebigman
    • 176
    What image are you using? Did you add a cam and chmod 755 it?
    thebigman
    • Devilfish
      Administrator
      • Feb 2008
      • 7872
      Delete the /var/tuxbox/config/zapit/services.xml file and pull the power to the box.
      When it reboots, set your location using the blue button menu (usually) then reboot again.
      Do a service scan, fast scan on, sections scan on, start scan.
      See if the epg works now.
      • harry1986
        • 516
        i removed the services.xml file and still get the epg coming up. im using the Pacino Image on Dbox2
