### New laky - sylas FTA image ###
  • jfish
    • 799
    #136
    Originally posted by emmajackt
    If you copied your old keys folder it will still have the old roms in there,so put the new rom7 into the var/keys folder,and delete the old 10,and 11 roms.Make sure that when you go into the CAMD-CFG folder (blue button-file manager) That the AU option (auto update)is set to 02.and not 00.Set location,reboot,and hopefully all should be working.
    Cheers,Kev.
    done all that, the var keys I used was taken from a working AU Image
    checking the process it seems like EvoCamd doesnt kick in at all as in the tmp folder I should see a EMM temp file with the necessary information, but this is never created
    also so someone who can answer this, when I telnet to the dbox and do a ps - should I see the evocamd process active, cant see it at all. Therefore I suspect evocamd to be the issue here, where exactly on the image is the evocamd binary located
    tried var/bin
    var/bin/emu
    cant see it
    • teddy.work
      • 24
      #137
      hi all, just downloaded the image (which is top notch by the way) put it onto my box but cannot connect to it. Went onto the box and got the ip address, put it in on the flashfxp and tried to connect but it wont. Any ideas?
      Cheers
      • bobsylas
        • 53
        #138
        tried var/bin
        var/bin/emu
        cant see it
        /bin/camd2
        • jfish
          • 799
          #139
          Originally posted by bobsylas
          /bin/camd2
          cheers
          should I see evocamd as a process when I do a ps -aux on the box - on the dreambox I can see the evocamd process.
          • bobsylas
            • 53
            #140
            cheers
            Yes mate give it a try
            • mickydibble
              • 2166
              #141
              cool
              • jfish
                • 799
                #142
                cheers
                had a look can not see evocamd as a process on the box
                also their is no evocamd in the bin/camd as for the location of the evocamd executable
                • bobsylas
                  • 53
                  #143
                  It is named camd2
                  and it lives in /bin
                  • jfish
                    • 799
                    #144
                    It is named camd2
                    ok got it now
                    is this camd just evocamd binary renamed
                    also what process should I see to ensure a EMU is running, only reference I can see is a process tmp/camd
                    • ukfun21
                      • 4
                      #145
                      i get a message thats says no channels found ??? am i doing this right ???
                      • bobsylas
                        • 53
                        #146
                        ok got it now
                        It is evo renamed
                        if you do a camd2 ps -aux
                        then change channel you will see what it is doing
                        • teddy.work
                          • 24
                          #147
                          can anyone help me and tell me how to put the keys onto the dbox and something else onto the scce part. i have no idea and have got this far from peoples help but no further. CAN ANYONE HELP?
                          • bobsylas
                            • 53
                            #148
                            keys go in /var/keys
                            use flashfxp or cuteftp
                            • Funnyguy
                              • 76
                              #149
                              hi quick question will i be able to use the image to flash by using the null modem cable method posted on this site
                              As i installed a image yet its in german so i was wandering if i could use this iamge to a get it o english (i had Commando before that worked fine...till the keys got blocked)
                              • jfish
                                • 799
                                #150
                                It is evo renamed
                                sent u a pm about this
