### New laky - sylas FTA image ###
  • Dask
    Fantastic Image!
    Thanks for all your hard work.
    • stevewild31
      • 81
      #197
      Setanta back
      Originally posted by stevewild31
      Hi guy's, I Like the new Image, got all channels up and running, but missing the setanta channels - when I try a scan (as recomended in another thread) I 'loose' all channels except for loads of teleport channels!
      can someone suggest what settings I should be using to do a scan that will leave all exsisting channels and bouquets and just add those that are missing ?
      Ok, I think there's a problem with the 'Stockport' location in 'set my location' I tried Ashton-U-Lyme instead, scanned and found ALL channels including Setanta, so If you are having problems scanning, try to set your location to another (local) town...
      • emmajackt
        • 13
        #198
        Anyone else had a problem with the audio sync going out on different channels,with this image?
        Cheers,Kev
        • bassethound
          • 65
          #199
          great image working great on 3 DBOX2,s supper fast channel changing love all the little tweaks you can play with.
          thanks to the team who put this together
          • konatist
            • 392
            #200
            cheers best image out there how they all should be
            • craigh8su
              • 10
              #201
              Lost
              I have succesfully flashed the box with the image and it is working. I have transfered the nagrom7 file to the keys folder. Yet I am not getting any channels, do I need to install "roms" . . . . . I have no idea can somebody please advise
              • misguided_fool
                • 20
                #202
                Press the blue button - go into the options there where you can select which roms you want. Disable all the roms except for rom7. Restart the box, put it on a cable channel and wait a few seconds.
                • craigh8su
                  • 10
                  #203
                  Thanks for the reply,
                  I have gone into the options and all of the other roms where already disabled, only rom7 was enabled.
                  Just to clarify the only tasks that I have done so far are:
                  Installed Laky 2x image onto the box,
                  gone to the /var/keys dir and transfered the file nagrarom7.bin file
                  then used a program called "Dbox2 FTP Key Updater Evocamd (by winker) V1.0.4" to add the latest keys.
                  The box boots up as usual, but doesnt find any channels when I scan, not even BBC or ITV. Please please please please show me the light .
                  • misguided_fool
                    • 20
                    #204
                    Have you selected your TV area before scanning ? (Im in Cardiff, but I just transfered my bouquet/service files rather than scanning)
                    • spankmonkeywill
                      • 48
                      #205
                      Superb image. Flashed on box and dropped nagrarom 7 into relevant folder. Smooth picture, very fast. I loaded this onto 3 boxes that i have had real trouble with sticking channels and it has been plain sailing ever since. BIG BIG thanks guys!
                      You cant disguise the smell ov Poo - - But you can sprinkle it with glitter!
                      • konatist
                        • 392
                        #206
                        i flashed this image 2 days ago set my location did a scan everything was fine a perfect image,,,,, the next day when i turned the box on i had lost all my channels they where they but couldnt view them so had to set my location and do another scan, and it was the same this morning seems to be if i turn the box off for say half a hour i loose my channels and have to set location and scan again, i love this image hope but whats wrong
                        • Derekwd
                          • 244
                          #207
                          I have used this image from launch, turn box off every night and never had a problem so its not the image at fault m8,might be worth a re-flash of the image to see if that helps.
                          Derek
                          • konatist
                            • 392
                            #208
                            ill do that cause i think i put everything on right keys folder bouquet/service and like i said everything works just when its off for longer then half a hour i have to re-scan its a cracking image tho
                            • konatist
                              • 392
                              #209
                              it did say somewhere on the imagen that it was without keys bouquet/service and something called VNC i dnot know what that is could that be at fault or should i just rescan thanks in advance
                              • Derekwd
                                • 244
                                #210
                                I just flashed the image put in the needed files set my location did a scan and never had a problem since.
                                Derek
