Cork city Netid
  • gav12345
    • 85
    Cork city Netid
    Cork city Netid
    ive looked everywhere and even in the place it should be but it aint there or any other sites
    Cork city Netid anyone please share so we can fix this problem
  • plasterer
    • 1631
    on your subscription box unplug from wall socket then on the box press and hold all the time the up and down arrow buttons on the box
    then plug in the power still holding down on these buttons you will get a engineers menu then let go of the down and up buttons
    in there you will find your netid and frequency and symbol rate
    press the right arrow on subscription box to flick through the pages where you will find this information
    write this information down then post on here
    to get out of the engineers menu simply unplug from mains and plug back in
    Hope this Helps ......paul
    PAUL
    • MetMan
      • 1091
      not recommended for subbed boxes as this activity is logged, recorded and can be viewed by v*m if talback ain't cut, which on a subbed box it won't.....best to do it on a modded box.
      • freck
        • 1076
        Originally posted by gav12345
        Cork city Netid
        I've sent a few pm's around gav and Im waiting for some response,I'll get back to you once I've got it.
        Thanks for your help on this.
        • gav12345
          • 85
          it says that on all boxes
          its fine to do just dont change anything
          it says that on my box
          • gav12345
            • 85
            this may help a little
            services + bouquets
            cork
            thanx to BigMAQ
            but if you can get the info that would be the best as this is a little old m8
            the netid you give me i will send you a file that will get all your channels scanned very very fast and pick up everything m8
            • freck
              • 1076
              Right gav I found this netid.
              Kildare Ireland C***** 01537.324.000 6875
              Its for kildare tho but scans on the 6875 symbol rate and the freqs will be in the xml that you gave me.
              Can you do anything with that?Would the same netid correspond to us here in Cork?
              • gav12345
                • 85
                overwrite it in var/tuxbox/config
                please unplug from mains only
                plug back in
                please report a scan result as we can put this into all future images m8
                • MetMan
                  • 1091
                  services + bouquets
                  cork
                  thanx to BigMAQ
                  u could have got a service file from here
                  Digital Kaos - Downloads - cork services and boquets
                  but it don't give u the net id and believe me on a subbed box v*m or chorus in this case will know if u been in the EM
                  • MetMan
                    • 1091
                    u could try this posted by mgb.....
                    Unzip the irish11.zip, upload the file cables.xml to var/tuxbox/config and let overwrite the old one, delete the file scan.conf in the same sub directory, pull the plug.
                    Replug, go to the scan menu, select n*l ie cable bf in the provider line, select keep/leave bouquets in the bouquet line, switch off fast scan, start the scan.
                    Some images have the cables.xml in the subdirectory share/tuxbox.
                    If you find a cable.xml there replace it.
                    irish11.zip
                    • freck
                      • 1076
                      i can do that metman but It would be easier just to have the fastscan option because when you need to scan your box it'll need to be reflashed because the previous netid is already on the box but I'll try your second method with the irish xml file and report back.
                      Christ every netid is available on the net except Cork......somebody must have it,in all fairness
                      • freck
                        • 1076
                        plug back in
                        I give it a go taday gav thanks again.
                        • elhefe
                          • 85
                          hi Freck
                          the net id is 6875000 based on my dm500 services . my dm500 will autoscan.
                          im going to assume that the 3 0's on the end are some thing that the dreambox needs
                          its on all my entries in my services so thats got to be it
                          hope this helps
                          • gav12345
                            • 85
                            that sounds like symbol rate m8 not netid
                            • elhefe
                              • 85
                              Hi Gav12345
                              where would this typically hide ? and what would it look like?
                              ive looked at my boquets.xml
                              <channel serviceID="0259" name="RTE One" tsid="0038" onid="0601"/>
                              is it the onid ????
