Oh my god what is happening to my box...?
  • smokey_jnr
    • 380
    for some reason this morning when i came to switch my box on this morning (i switch my box off every night) no matter what channel i goto after about two minutes it freezees it gets very pixalated and then when i change channel it comes up channel not available, then a few seconds later the pic comes back up again..
    then two minutes later it freezes again and the i have to go through the whole thing of channel changing...
    please break it to me gently, is my box dying..?
    ta very much
    smokey_jnr
  • plasterer
    • 1631
    Try the Box Direct to the wall mate
    if that helps mabe a booster will do the trick.....Paul
    PAUL
    • gani12
      • 11
      Freezing Box
      What Image are you using I'm using two Images on mine which are very
      good (Laky pro August08 and Commando 9.25) My Setup is Nokia Dbox2
      Try and change your Image maybe that will cure it
      • smokey_jnr
        • 380
        i using blade quad.. it was working a treat all of sudden now its started playing up...
