DBOX Problem
  • deejayy
    • 12
    DBOX Problem
    I flashed my dbox with sylas.
    and used the auto ftp updater to add the keys.
    however, most of the channels are still locked.
    what am i doing wrong? have i missed a step.
    i also added the teesside services.xml
  • Jaffa
    • 1612
    Go to link below and get the new fix and follow the instructions.
    • deejayy
      • 12
      Thanks for that,
      However, still no joy.
      my folder is /var/keys, however there is a /var/scce shortcut folder which just takes me into /keys/
      Inside this folder is Keylist.txt and that is all. Nothing with rom10 or room11. Regardless, i copied the nagrarom7 to this folder but still had no joy.
      To summarise what i originally done:
      1. Flashed the box with Sylas (from Sportster)
      2. Used the Auto FTP updater to add the keylist file and keys within it.
      3. Changed the services.xml file to Teesside, as it seemed to be at Anglia as default.
      I was give some other keys on another forum, that are alot shorter than the keys added by the program. Non have worked.
      I am on Virgin Media, in the Teesside area.
      Any ideas?
      • Jaffa
        • 1612
        Originally posted by deejayy
        Thanks for that,
        Any ideas?
        Laky-Sylas is FTA only, thats why there are no rom files in it, you need to have saved a set or get the ones from below and ftp them across, then follow instructions to put the fix back on.
        http://www.digital-kaos.co.uk/forums...00-c-s-t-3872/
        • ksbps
          deejayy, I am also on Teesside and although a newbie I have just flashed Laky-Sylas and all is up exc ppv
          Check your k*ys with keymaster and make sure 01 and 02 sequence are correct.
          Hope this helps
