please help
  • tankthemuss
    please help
    im a newbie to all this cable stuff but here is my question i got a dbox 2 nokia and i flashed it with the sportster menu and plugged it in and manually changed the new keys and i got no channels only freeview any ideas thanks tank..
  • standarren
    • 857
    what image have you got have you done a service scan what softcam are you using mgcamd gbox newcamd
    • toto67
      • Feb 2008
      • 178
      Ok m8,was the box originally working before you flashed it? Its just probably the keys folder/file you have ftp'd over dont contain the correct keys or maybe even any keys m8..Have you even got a backup image that you have previously used?
      • grim
        • 5
        it looks like im going to have to load an old image to obtain keys.txt.
        • toto67
          • Feb 2008
          • 178
          Its not that bad m8..Then all you need to do then it copy the keys folder,reflash whatever image you fancy and then FTP the copied keys folder over and then you will be sorted..But why the need to change to a new image? Where you having problems?
          • tankthemuss
            thanks alot that helped a lot im all sorted now
