cant connect dbox to laptop
  • rob6007
    • 152
    hi guys its been that long since i connected my dbox to my laptop i cant get it done right now .
    i have flash fxp . can sum1 please tell me what i put in when i go to connect . ip address username etc .
    thanks guys rob
  • Jaffa
    • 1612
    Heres a guide to ftp for you. Please when you go to the link below would you click the thanks button in the 1st post, mubz spent some time putting that guide together.
    btw...the username is root and password is dbox2 (or if its a commado image the password will be commando)
    • Derekwd
      • 244
      Need to know what image you have on your box m8, most images (but not all) are user name = root password dbox or dbox2.
      Derek
      • Salami
        • 535
        thanks guys rob
        I hope this PDF may help M8.
        If you like my post pleas click on the little button to say thank you.
        • Salami
          • 535
          Sorry Jaffa M8 that was a bad crossover we must have had the same idea just took me a bit longer to find the PDF in my Lappy, and you were too fast for me. Cheers
          • Salami
            • 535
            And also sorry 4 the repeat.
            • rob6007
              • 152
              its just digitalword image i think .
              i have tried and cant get the connection .
              do i have to set up a connection on my laptop .
              and what about the dhc . sum1 on another post said it needs to be on .
              thanks .
              the last time all this happend i got connected no probs this time for the life of me i cant get it .
              thanks again for the replys guys
              • rob6007
                • 152
                i have tried everything in hte link but still cant connect it to my laptpo .
                is there another way to set up the connection .
                any help would be great
                • Salami
                  • 535
                  Whitch FTP client you are using M8.
                  • rob6007
                    • 152
                    im using flash fxp thanks .
                    everytime i try it says please specify the password then 530 login incorrect
                    • Salami
                      • 535
                      Have you set up your Local Area Conection correctly?
                      Are you using XP or Vista Operating System?
                      • rob6007
                        • 152
                        would flash fxp be correct
                        • rob6007
                          • 152
                          its vista im using . i think i have set the connection correct but i konw something doesnt seem right .
                          when the boxes went down the last time it didnt seem as difficult to connnect the box.
                          i didnt connect the box again after the last problems incase i done sumthing wron g to the box .
                          thanks for the help salami
                          • Salami
                            • 535
                            Please do this check for me once more by clicking on this link.
                            once is done and you are sure of it then I will go through the FTP connection.
                            If you can download Filezilla it would an advantage to use with Vista.
                            I use it with my Laptop and Vista Windows, and is always spot on.
                            I will try to upload Filezilla to the Download section.
                            • rob6007
                              • 152
                              thanks sal i will give the link a check .
                              i will check back after i have done that if you have the link great if not i will get it myself im sure thanks
