H E L P ! ! !
If you like my post pleas click on the little button to say thank you.Comment
just to confirm mate if you cant see your ip adress in network settings its probably because the dhcp is on what you need to do is press show settings it will show you the ipadress of the dbox dhcp bassically means that it will sort all the ip settings out so you dont have to thats why its blankComment
how u doing with your ip i changed ,mine 2. 192.168.0.202 thats 4 the dbox had no promblen with the ftp with that then change u com ip its in network connections local area 1 u want .then click properties.scorl down internet protocol click properties click use the following ip address then put in 192.168.0.202 .Comment
