Help Reading IFA Issue
  • Scooter
    • 16
    Can any of you smarty pants help me with an issue i have.
    I have been playng with a Nokia 2x for a while now and cannot get the git going.
    I nearly had it on Sunday but when in ftp had a smart idea to delete var folder and use the one from a working box.
    Trouble is it would not let me re-enter.
    I have tried to ifa new image but getting this error.
    If anybody can help it is worth a beer or two as i am like a dog with a bone at the moment.
    debug: DDF: Calibrating delay loop... debug: DDF: 67.79 BogoMIPS
    debug: BMon V1.0 mID 01
    debug: feID 7a gtxID 0b
    debug: fpID 5a dsID Hallenberg.com
    debug: HWrev X5 SWrev 0.81
    debug: B/Ex/Fl(MB) 32/00/08
    WATCHDOG reset enabled
    debug: autoboot aborted from terminal
    dbox2:root> boot net net net net net net net net net net
    debug:
    BOOTP/TFTP bootstrap loader (v0.3)
    debug:
    debug: Transmitting BOOTP request via broadcast
    debug: Given up BOOTP/TFTP boot
    boot net failed
    debug:
    debug:
    #debug: DDF: Calibrating delay loop... debug: DDF: 67.79 BogoMIPS
    dbox2:root> debug:
    debug:
    boot net failed
    Flash-FS bootstrap loader (v1.5)
    Found Flash-FS superblock version 3.1
    Found file /root/platform/nokia-dbox2/kernel/os in Flash-FS
    debug: Got Block #0032
    debug: Got Block #0004
    debug: Got Block #0008
    debug: Got Block #0012
    debug: Got Block #0016
    debug: Got Block #0020
    debug: Got Block #0024
    debug: Got Block #0028
    will verify ELF image, start= 0x800000, size= 154360
    verify sig: 262
    Branching to 0x40000
    U-Boot 1.2.0 (Tuxbox) (Nov 21 2008 - 18:36:13)
    CPU: PPC823ZTnnA at 67.200 MHz: 2 kB I-Cache 1 kB D-Cache
    *** Warning: CPU Core has Silicon Bugs -- Check the Errata ***
    Board: DBOX2, Nokia, BMon V1.0
    Watchdog enabled
    I2C: ready
    DRAM: 32 MB
    FLASH: 8 MB
    Scanning JFFS2 FS: . | / - \ | / - \ | / - \ | / - \ . | / - \ . | / . - . \ | / - \ | . / .  done. find_inode failed for name=var load: Failed to find inode FB: ready
    LCD: ready
    In: serial
    Out: serial
    Err: serial
    Net: SCC ETHERNET
    find_inode failed for name=var load: Failed to find inode ready - can't find logo in flash
    find_inode failed for name=var load: Failed to find inode can't find logo in flash
    Options:
    1: Console on null
    2: Console on ttyS0
    3: Console on framebuffer
    Select option (1-3), other keys to stop autoboot: 1  0
    ### FS (jffs2) loading 'vmlinuz' to 0x100000
    ### FS load complete: 670262 bytes loaded to 0x100000
    .................................................. ............. done
    Un-Protected 63 sectors
    ## Booting image at 00100000 ...
    Image Name: dbox2
    Image Type: PowerPC Linux Kernel Image (gzip compressed)
    Data Size: 670198 Bytes = 654.5 kB
    Load Address: 00000000
    Entry Point: 00000000
    Verifying Checksum ... OK
    Uncompressing Kernel Image ... OK
    Linux version 2.4.36.6-dbox2 (ubuntu@bob-desktop) (gcc version 3.4.6) #3 Fri Nov 21 18:40:41 GMT 2008
    On node 0 totalpages: 8192
    zone(0): 8192 pages.
    zone(1): 0 pages.
    zone(2): 0 pages.
    Kernel command line: console=ttyS0,9600 dbox_duplex= root=/dev/mtdblock2 rw rootfstype=jffs2
    Decrementer Frequency = 252000000/60
    m8xx_wdt: active wdt found (SWTC: 0xFFFF, SWP: 0x1)
    m8xx_wdt: keep-alive trigger installed (PITC: 0x12C0)
    Console: colour dummy device 80x25
    Calibrating delay loop... 66.96 BogoMIPS
    Memory: 30824k available (1140k kernel code, 344k data, 60k init, 0k highmem)
    Dentry cache hash table entries: 4096 (order: 3, 32768 bytes)
    Inode cache hash table entries: 2048 (order: 2, 16384 bytes)
    Mount cache hash table entries: 512 (order: 0, 4096 bytes)
    Buffer cache hash table entries: 1024 (order: 0, 4096 bytes)
    Page-cache hash table entries: 8192 (order: 3, 32768 bytes)
    POSIX conformance testing by UNIFIX
    Linux NET4.0 for Linux 2.4
    Based upon Swansea University Computer Society NET3.039
    Initializing RT netlink socket
    Starting kswapd
    devfs: v1.12c (20020818) Richard Gooch ([email protected])
    devfs: boot_options: 0x1
    JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
    squashfs: version 3.0 (2006/03/15) Phillip Lougher
    i2c-core.o: i2c core module version 2.6.1 (20010830)
    i2c-dev.o: i2c /dev entries driver module version 2.6.1 (20010830)
    CPM UART driver version 0.04
    ttyS0 at 0x0280 is on SMC1 using BRG?ttyS1 at 0x0380 is on SMC2 using BRG2
    pty: 256 Unix98 ptys configured
    half-duplex mode enabled
    eth0: CPM ENET Version 0.2.dbox2 on SCC2, 00:50:9c:1b:be:b7
    loop: loaded (max 8 devices)
    D-Box 2 flash driver (size->0x800000 mem->0x10000000)
    D-Box 2 flash memory: Found 2 x16 devices at 0x0 in 32-bit bank
    Intel/Sharp Extended Query Table at 0x0035
    cfi_cmdset_0001: Erase suspend on write enabled
    Creating 5 MTD partitions on "D-Box 2 flash memory":
    0x00000000-0x00020000 : "BR bootloader"
    0x00020000-0x00040000 : "FLFS (U-Boot)"
    0x00040000-0x00800000 : "root (jffs2)"
    0x00020000-0x00800000 : "Flash without bootloader"
    0x00000000-0x00800000 : "Complete Flash"
    Linux video capture interface: v1.00
    mice: PS/2 mouse device common for all mice
    NET4: Linux TCP/IP 1.0 for NET4.0
    IP Protocols: ICMP, UDP, TCP
    IP: routing cache hash table of 512 buckets, 4Kbytes
    TCP: Hash tables configured (established 2048 bind 4096)
    NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
    VFS: Mounted root (jffs2 filesystem).
    Mounted devfs on /dev
    Freeing unused kernel memory: 60k init
    Kernel panic: No init found. Try passing init= option to kernel.
    <0>Rebooting in 180 seconds..
    ------ Systeminformations ------
    Selected networkdevice: Realtek RTL8139 Family PCI Fast Ethernet NIC - Packet Scheduler Miniport (0)
    IP-address of the networkdevice: 86.10.177.117
    IP-address which the dbox gets: 86.10.177.202
    Operatingsystem: Microsoft Windows XP Home Edition Service Pack 3 (Build 2600)
    ------ Powered by Hallenberg.com ------
