DBOX Commentary
  • punjabi boy
    • 117
    DBOX Commentary
    Firstly just to say a big big thanks to all for all the help for the latest Dbox fix.
    Please can anyone help me in getting rid of the commentary that is present on some programmes. I think I need to flash a new imgae would that be right?. Can anyone help me on this?..Which imgae do i transfer onto the box and in which directory?..I am using FlashFXP
    many thanks
  • father ted
    • Feb 2008
    • 1389
    press the audio button you ll get a screen it will say english and nar goto english ,nar is for naration easy m8
    • punjabi boy
      • 117
      hi thanks for the reply. tried that. there is no audio button on my remote. if you mean the green button well that did not work for me. i have been told it needs a new image flashed on it....???
      • CharismaPro
        • Oct 2008
        • 51
        how abot the volume?,,,,,compaired to other hardware the signal output from the audio on the 500c is so low...any edit to increase this?.
        • punjabi boy
          • 117
          hi it is a SAGEM DBOX thar i have. Anyone know how to fix this problem?
          • father ted
            • Feb 2008
            • 1389
            trust me there is an audio button not sure which one on a sagem put it on a cghannle and go through them all it is there
            • punjabi boy
              • 117
              Tried the green button. Says Audio on the screen but it goes straight to the radio........any ideas?
              • Salami
                • 535
                For Sagem
                d-box button/ok/Settings Menue/ok/Audio/ok
                If you like my post pleas click on the little button to say thank you.
                • jfish
                  • 799
                  think your image may not support it, if I recall when I got my DBox 2 years ago had same issue, pressing green kicked the radio in, changed image and got sorted
                  wot image are you running - not an sportster
                  • punjabi boy
                    • 117
                    cannot see any NAR (naration) setting or option...any chance you could just guide me into where exactly it is?.thanks
                    • jfish
                      • 799
                      what should happen when you press the audio button box pops up with 2 audio streams just select the other audio
                      what image are you running
                      • punjabi boy
                        • 117
                        Originally posted by Salami
                        For Sagem
                        On this page i have the following:
                        ANALOG OUTPUT STEREO
                        DOLBY DIGITAL ON
                        VOLUME CONTROL AVS
                        There are no other options or setting to fiddle around with
                        • winker
                          • 19
                          Dbox
                          Settings
                          Audio
                          Audio Selection with L/R <- set this to on,
                          Back
                          Save Settings
                          Then when the current programme info bar has gone, press left or right arrow for next audio stream.
                          EDIT
                          Sorry posted before I saw your post above
                          • punjabi boy
                            • 117
                            Sportster V6....Also says Neutrino
                            • punjabi boy
                              • 117
                              Originally posted by winker
                              Dbox
                              Settings
                              Audio
                              Back
                              Save Settings
                              EDIT
                              Do not have the following:
                              Any ideas? The narration drives me nuts!
