no IP
  • skinterz
    • 89
    no IP
    alright
    i flashed a new adromeda image to my dbox,but cant seem to find the IP in settings.
    i was hoping to install the nagrarom7 into the var but need the IP
    any ideas ?
    cheers
  • scubar
    • 206
    dbox button, down to network press ok should be there mate.
    • nkw59
      • 41
      Originally posted by skinterz
      alright
      any ideas ?
      cheers
      have you got DHCP set to on,if you have it wont display an ip address in the network settings...then you will have to input an ip address.I always set mine to 192.168.100.10,then i set my laptop static ip to 192.168.100.09.
      • skinterz
        • 89
        no network on there mate
        ive looked right through ,thing is how can i reflash another image without the IP?
        • skinterz
          • 89
          sorry lads panic over network found must be going blind in my old age thanx for the quick replies
          • Mubz
            • 168
            you can flash it with a NULL modem cable.
            you don't need an ip addy for that...
            Mubz
            Growing old is inevitable, growing up is optional ...
            • scubar
              • 206
              it will be there somewhere mate, try (i think) either miscellanious or preferances and the network will be set to NOT VISIBLE click ok on that and it will change to VISIBLE and you'll be able to view it via the dbox button then.
