easy guide get your channels back
  • standarren
    • 857
    hi guys i've seen a lot of people struggling over the past few days i've put this together to help you get your channels back all this information is courtesy of the other great members including crazy legs here we go
    first thing is to connect box to your tv and find out it's ip addresse. some along the lines of menu--settings--expert setup--communication setup.
    once you have that write it down so you dont forget it then connect dbox to your router using the RJ45 cable.
    load flashfxp if you dont have it you can download it here - FlashFx_and_guide.rar
    download keys from here dreambox_stuff.rar
    extract them to your desktop and you'll see there is 2 folders var/keys and var/scce
    load flashfxp and you'll see 2 sides to it. on the right hand side just under the options click on the very last little box so it shows a world and a pc and on the left hand side again the very last little box click it so it shows a pc and folders.
    click on the lightening bolt and input your dbox ip in the server or url box.
    username is root
    password is either dbox or dbox2 unless its different and stated in the iage write up.
    now on the right hand side once you enter all that stuff hit connect and you should see lots of folders like /var /bin /tmp etc.
    double click on var then on keys
    on the left hand side navigate into the var/keys folder you downloadede earlier then highlight all the files within that folder then right click and press transfer.
    now once they have transfered succesfully navigate to var/scce on the right hand side.
    back on the left navigate back into the folder you downloaded but this time the var/scce folder and agian copy all files over to the dbox
    lastly copy the rom7 update to the var/keys
    it has been said to delete other roms but please dont leave all the files alone
    i found it worked better
    once they have all copied over reboot
    this is how i got mine to work hopefully you can tp dont forget the thanks button its nice to be nice
  • brownie2179817
    thanx
    hey thanx alot uve been a big help
    • angrycat
      • 165
      Will this Method Work for Dbox2?
      • Funnyguy
        • 76
        hi there do you need an rj45 cable or can you justuse a normal ethernet cable?
        tahnks this tutorial makes it sound easy :-) just hope it is when i get to do it
        • daisy-lucy
          thanks just got back off holiday and wondered what had gone on dont really understand what you have said but will keep reading it till i do
          • eb01
            thanks v much
            • punjabi boy
              • 117
              Copied all the files into the VAR/KEys folder . Reset the box and I am getting the "WAITING FOR TIME" MEssage with no channels. Tried arescan and it was no help. Any ideas?.. Should say I am trying on a DBOX1 for a friend. I myself have a DBOX2 and it worked without any problems.
              many thanks
              • $Furious
                • 27
                Iv done this and it worked but when i tried to scan for new channels today all my channels went missing agian.
                • wal
                  i tried this on a dbox2 it does not seem to work, can anyone help?
                  • wal
                    i just have a black screen and only some FTA channels, what am i doing wrong?
                    • standarren
                      • 857
                      i'l try and clear up a few comments dont think this will work with a dbox 1 add your services file through flash fxp or do a rescan leave your box on skysports 1 for a minute or so after you reboot add or edit new keys to the updated ones down load hereKeyMaster_v1.2.zip
                      • standarren
                        • 857
                        to get your dbox working again you really need to have basic knowledge of ftp editing using flash fxp its really easy theres some guides on the forum have a good look around it took me a wwhile but i managed to sort mine out after a while with the information provided
                        a few things i would like to add if you feel your not getting anywhere reflash your dbox and start again i often flash my dbox through yweb from my wireless laptop its something like settings image flash without bootloader works every time as long as your network is connected to the box if with a standard network cable you can connect your pc directly to your box but that lead is slightly different its a crossover cable that looks pretty much the same as a standard network cable have a good look round the site take your time and fammiler yourself with the instructions
