Flashing an image onto Nokia Dbox2
  • teddy.work
    • 24
    HI all, i am in the middle of flashing an image to my dbox by using a crossover cable and IFA. I started it at 4 o'clock and was wondering if it was working or i just takes that long. The other thing is should i restart it or plug the arial back into the box. All help would be great as i have been trying to do this since yesterday morning.
    Thanks Jay
  • Jaffa
    • 1612
    I am sort of glad yu started your own thread as the other one was about seperate issue.
    Can I ask why you are using IFA....is the box in kein system or not working for some reason ???
    • teddy.work
      • 24
      what do you mean "kien system"? it was working one minute and the next morning it wasnt. There are little keys on the programme bar, which i think it means locked. I have no idea what i am doing and am just trying to get as much help as possible.
      I tried to reboot but nothing still, all the channels are there but they are blank. The only ones i get are 1,2,3,4,5 and itv2.
      I am using IFA as its the only thing i have heard anything about and only have a crossover cable.
      • toffeeman
        • 10
        Are you not using a null modem cable as well?
        The reason I ask is that is how I flash my 'kein sysytem' box if that is what you have!
        I also use IFA.
        • teddy.work
          • 24
          I have no idea what "kien system" means. I just plug the crossover cable into my laptop and then into the box. no sorry, i just have been using the crossover cable. Its whats i was told to get.
          • Jaffa
            • 1612
            So you can actually get into the dbox menu ??? If so you do not need IFA, thats for when you cant get into the dbox at all.
            • teddy.work
              • 24
              yes i can get onto the menu, i can do everything apart from watch the channels.
              • Jaffa
                • 1612
                O.K m8, hook it up by ftp. Are you using flashfxp. Doesnt matter what ftp client you use.
                ftp the image from your pc to the /tmp folder on your dbox
                with your remote control go to.
                dbox
                service
                it will either be flash/backup image or expert fucntions (depending on image)
                flash one partition
                flash without bootloader
                a box pops up, highlight the image
                press red
                When finished it will reboot and you can then add the keys folder and new roms
                • teddy.work
                  • 24
                  sorry, i am not sure what you mean. i have put the crossover cable in and in the back of the box. brung up the flashFXP im not sure what to do next. i am a total newbie at the whole thing, and may need the full step by step guide, SORRY. and what does ftp mean?
                  • Jaffa
                    • 1612
                    Dont worry about being new.
                    You have used flashfxp before ???
                    • teddy.work
                      • 24
                      nope, first time today. is this bad? im a quick learner though
                      i used to be a regular guy until cable ripped me off thats why i decided to get one of these.
                      • Jaffa
                        • 1612
                        Connect to dbox with crossover cable
                        Start flashfxp
                        press F4
                        you will get a window pop up, click new site
                        another window will pop up, type it any name...best to use dbox.
                        put the dbox ip address in where it says ip address
                        username is root
                        password is dbox2
                        click apply and connect
                        once connected on the right side screen, go to /tmp and on the left side go to wherever your saved image is, highlight it and press the transfer button at the top of left side, its like 2 arrows one green and orange.
                        then go to my other post about using your remote
                        • teddy.work
                          • 24
                          i cant find the post which tells me, where bouts is it
                          • teddy.work
                            • 24
                            ignore that sorry, when that has done where do i get the keys and the roms from. and how do i put them in. i really do appreciate this and thank you for all your patience. Cheers
                            • Jaffa
                              • 1612
                              You can get the keys below, just extract to your pc then ftp to /var/keys
                              RapidShare: Easy Filehosting
                              then you need to apply the fixed roms, get then below and extract to your pc and ftp to /var/keys, overwriting the other ones.
                              reboot and put on the likes of SS1 and wait for it to update the keys.
