Right ive found setanta on another net ID. Only problem now is that I need to scan 2 net ID's because when i scan one I get setanta and when i scan the other I get all the other channels but loose setanta....
There must be a way to scan all of 6952 using Laky Stylas but i'll be buggered if i can find out how
You could do a slow scan and see if that gets them or try this
Open the working SetantaSports services file in wordpad and find what transponder its on
then copy it to your "myservices" file like this and put whats hilited in red then reload channel lists in the service menu
<transponder id="0076" onid="f020" frequency="354750000" inversion="2" symbol_rate="6952000" fec_inner="3" modulation="3">
<channel service_id="00b4" action="add" name="SetantaSports1" service_type="01"/>
</transponder>
</cable>
</zapit>
Its not just about finding setanta. I can do that using lincsat image. Its just laky Stylas image has a problem and i just want to work out how to set the scan to scan all UK.
