Post laky install problems
  • Slainte.Celt
    • 28
    Hey guys,
    I'm in the Uddingston area and a \/M cust0m3r
    I have the Nokia DBox2 and have flashed (through null modem only) the new Laky Stylas x2 image.
    When I set my location, nothing happened. In fact, on reboot and scan attempt, I get (NO CHANNELS FOUND, EXECUTE SCAN)
    I am having trouble ftp'ing into the box too, which I'm currently working on. Is there anyone who can tell me EXACTLY what I need to do now to "completely 'sort' this box out"
    Thanks, I got 4 more waiting and need to 'fix' my own first.
    edit: I realise the SEARCH tool is invaluable but have been searching since I joined the forums yesterday and have found nothing matching my problems. Thanks
    Slainte
  • Kingcory
    • 30
    Have you got a crossover cable for FTPing to box mate ?
    If not you can make one from a straight cable like i did.
    • Slainte.Celt
      • 28
      I'm not sure what type of ethernet cable I have nor do I know how to find out, I'm afraid.
      • Kingcory
        • 30
        This isnt as hard as it looks just cut you straight cable in half then reconnect using the diagrams.
        Ethernet Crossover Cable - DIY How-to Guide
        LWD - How To Make a Crossover Cable
        • no1superguy
          • 45
          or nick down to maplin and buy one;
          CAT 5e Cross-Over Cables > Maplin
          • Slainte.Celt
            • 28
            okheres the problem. when i connect up the comp to dbox and set ip etc. my LAC says its connected 10.0 MB/s
            when i go to ftp client and attempt to connect, it tells me ETIMEDOUT
            wtf
            the comp is set to 1 point less on IP than box(.1.109), and I connect in box to .1.110
            anyone able to go msn with me for a sec?
            • Kingcory
              • 30
              You will never connect if its a straight cable mate. You need a crossover cable or its just not going to happen sorry ....
              • Slainte.Celt
                • 28
                i have dozens of ethernet cables here. I just don't know how to tell the difference...
                • Ultim8
                  • 59
                  Right here is what a crossover should look like, if both ends are identical (same color to same pin) you have a straight thru
                  Note: The hook is underneath in all cases and Pin one is always on the Left
                  PIN 1 white orange
                  PIN 2 orange
                  PIN 3 white green
                  PIN 4 blue
                  PIN 5 white blue
                  PIN 6 green
                  PIN 7 white brown
                  PIN 8 brown
                  PIN 1 white green
                  PIN 2 green
                  PIN 3 white orange
                  PIN 4 blue
                  PIN 5 white blue
                  PIN 6 orange
                  PIN 7 white brown
                  PIN 8 brown
                  Let us now
                  • Slainte.Celt
                    • 28
                    outstanding, i have one and am in the ftp of the box...phew!
                    kudos to Ultim8!!
                    now what...?
                    • Ultim8
                      • 59
                      right what do you want to do? ftp over roms and keys?
                      • Slainte.Celt
                        • 28
                        yeah, I want to be able to get all channels available, using this image.
                        sorry for the delay in responding, I was working.
                        • Slainte.Celt
                          • 28
                          anyone have any ideas?
                          • mickydibble
                            • 2166
                            rom 7 fix into var/keys folder ,reboot box
                            • Slainte.Celt
                              • 28
                              done that. nothing.
