were to put codes
  • phil73
    • 4
    were to put codes
    Hi am the need of help i can get new codes i know were to put them but do i edit an old code or start a new one and i not sure if am pure N*l oe ex C AND W or what am in ellesmere port area can any one help with a guide or advice as am in the SH*t with no channels plaese help
  • littlelou
    • 44
    u click ok on the line that needs changing then enter the code
    • mickydibble
      • 2166
      press number 4 on keylist.txt that brings it in to edit mode then ok/select on code your going to change,then edit key and go back saving all the way then reeboot box
      • phil73
        • 4
        i have a list of about 23 codes do i use the last 2 that are key0 and key1 and how do i find out what codes to use
        • phil73
          • 4
          is it the last code or the first as i have about 23
          • mini
            • 602
            the top 2 lines need to be edited, why dont you just add the fix instead. you can find it on here.
            Download this and ftp it to your box in the var/keys folder then you wont have to keep changing keys.
            • phil73
              • 4
              i have no idea how to or were it is if you can help it would be greatfully recieved
              • mini
                • 602
                downoad this link http://rapidshare.com/files/169555753/new_roms.rar
                • moin
                  • 178
                  i can not download any thing pleas help me
                  • mini
                    • 602
                    pls explain more clearly, you saying that link is not available.
                    • gizmo.1484
                      • 873
                      It can take up to an hour for your account to up date so you can download m8
                      • mickydibble
                        • 2166
                        edit keys first then do a bit more reading/asking questions to understand how to do update or you will need other items/instructions and you may get lost.
                        • mo.p
                          • 298
                          hi m8 i think u need more then 5 posts m8
