Eurovox Tx setup
  • heelanj
    • 10
    Eurovox Tx setup
    Hi there, having some issues setting up a Eurovox Tx system. Remote is not allowing me setup and you cant select manually from the unit. Not battery issues either, Its a new unit so i'm hoping not hardware fault, maybe firmware?? Any tricks to help me on this one... thanks. Happy xmas
  • satsmo
    • 6397
    Have you flashed it with the latest firmware?
    • heelanj
      • 10
      Not as yet, don't have the correct app to do it and not sure if thats the problem??
      • satsmo
        • 6397
        Try it and see Digital Kaos - Downloads - Fix for MMDS version of EuroVox if you need the loader you will find it in downloads also, with the previous firmware revision.
        • heelanj
          • 10
          Hi, ya downloaded it sucessfully, still can't seem to connect with remote..
          • satsmo
            • 6397
            Have you checked the remote via a camera phone or similar to see if the IRD is working?
            • heelanj
              • 10
              it defo works!
              • heelanj
                • 10
                Actually, think i have sussed it, the remote is a eurovox max V, but system is Eurovox TX. Should this really make a difference??
                • satsmo
                  • 6397
                  Yep but why did they send you a Max V remote. The TX remote is this one:
                  • heelanj
                    • 10
                    Anything i can do now...? any way around it?
                    • satsmo
                      • 6397
                      Not without the correct remote, unless you know someone in the neighbourhood with one?
                      • heelanj
                        • 10
                        Will have to see, not easy to get one at this time, but really appreciate the help!
