help (eurovox max blue)
  • markyboy
    • 6
    i have flash with latest firm ware but cant get it to work the display says 0001 and cant be change, on the tv it is a blank screen someone please help
  • smirnoff_rules
    • 8603
    its a clone ,,,
    forget the scart for now and use an areail lead and tune tv in till u get a picture and then put the code 1004 in and goto settings and do a factory reset and it will scan and then put the scart back in .. make sure u have the clone blue firmware on it first
    clone safe here
    • camelv
      • 1202
      heres how to
      your box may be a clone. BEFORE YOU DO THIS FLASH WITH F/WARE FROM APRIL 08 .TO GET THE F/WARE D/LOAD BIGMAQ TOOLBAR AND CLICK ON FILES AND FIXES, YOU WANT THE BLUE BOX FLASH FROM 21/04/08.heres what u do take out the scart lead form ur eurovox and tv
      connect a coxial cable from the back of ur eurovox to ur tv (a coxial cable is the one u use to connect ur vcr to ur tv )
      ok now u have ur eurovox connected to the tv by coxial cable only have ur eurovox on and not in standby but on
      now using ur tv remote scan the channels on ur tv do an automatic scan of channels on ur tv u should get to a screen asking for a code the code using ur eurovox remote now is either 0000 or master code 1004
      now u will press menu>goto config>cleardata>clear channels>factory default ?choose correct symbol rate then power scan.once your box is back on flash it with the blue box clonesafe f/ware.
      its the stuff we think we know that stops us all from learning
      • cowplain35
        • 138
        The new blue back ground for the site,i don't like it,go back to the original,that's my opinion.
        • HiTeck
          • Oct 2008
          • 996
          Change it yourself, bottom left hand side of the page there's a pull down box, click on that and change it to charcoal.
          • markyboy
            • 6
            will try it asap and let u know how i get on
            • markyboy
              • 6
              box now working thanks your help smirnoff &camelv
