Eurovox CDF files all compatible?
  • bobey99
    • 15
    hi,
    i've a EX1000SL eurovox...
    is it possible to use the channel dump file CDF of another type of eurovox say the Max?
    also..there was a update file for the Max V that autosorted the channels, would this work on the EX1000S ??
    cheers
    paul
  • HiTeck
    • Oct 2008
    • 996
    Yes you can use CDFs from one type eurovox for another, with regards to the firmware there has only been one released as far as I know, http://www.digital-kaos.co.uk/forums...ix-011208-432/
    • bobey99
      • 15
      hi HT,
      thanks for the swift replay...
      that helps me alot, all i need to do now is find an up-2-date Belfast CDF file!!
      regarding the autosort update, i 'm not certain on what forum i found it, but it was called 'UFL_MAX_V_Autosort_5_12_08'
      if u want it, just let me know!
      cheers
      paul
      • HiTeck
        • Oct 2008
        • 996
        Yep thats available here too Digital Kaos - Downloads - UK Max V Autosort Fix 051208
        I thought you wanted a auto-sort firmware for the EX1000sl, I read your post wrong mate .
        Just to clarify you can use CDFs on other EV but you cant use max V firmware for ex1000sl which i'm sure you are aware of.
        All the best mate.
        • bobey99
          • 15
          hi,
          yip...i knew about he firmware..
          thanks again for your help & input
          cheers
          paul
          • HiTeck
            • Oct 2008
            • 996
            Your welcome mate, all the best.
