EUROVOX EX 5000 PVR and Midnight
  • andy4
    • 1125
    #16
    same probs for me hdd bag of shite shud of kept with linux boxes
    WIGAN ATH the BLUE BRAZILIANS
    DWSTADIUM the theatre of SCREAMS
    <<<<--------if i've been helpful hit the Thanks button
    • dreamreaper
      • 5
      #17
      Yep mine does it with the hd installed
      • victor_ray
        • Oct 2008
        • 106
        #18
        I have just read thorough the thread again from the beginning.
        Has anyone actually following HiTeck instructions by doing a factory reset and then a power scan.
        I am going to give it a go tonight and see how I get on obviously after the football!
        Will keep you posted.
        • andy4
          • 1125
          #19
          yeah m8 done all that nothing wrong with box it's just the hdd that people having probs with
          • victor_ray
            • Oct 2008
            • 106
            #20
            Do you think different makes of HDD may make a difference.
            I know they say the box will work with a Western digital or Segate HDD
            I am using a Western digital HDD and the problem happenes.
            • HiTeck
              • Oct 2008
              • 996
              #21
              I'm using a WD hard drive and mine works fine. I used to have this problem until I flashed the box with the HD out using the autosort firmware, re-inserted HD, factory default including erasing all the recordings and its been fine every since.
              • victor_ray
                • Oct 2008
                • 106
                #22
                Ok thanks for that.
                I will do it exactly the same way.
                After flashing the box, can I download my saved CDF file or should I do a fresh power scan?
                • HiTeck
                  • Oct 2008
                  • 996
                  #23
                  I used my own CDF so it should be fine, best of luck.
                  • victor_ray
                    • Oct 2008
                    • 106
                    #24
                    Last night I followed HiTecks instructions to fix my Eurovox EX5000PVR from turning off at midnight and it worked:-
                    1. Take out the hard drive.
                    2. Reflash the box with the latest firmware even if you already have it.
                    3. Re insert the hard drive and connect up to TV.
                    4. Do a factory reset and clear all data on the HDD.
                    5. Rescan for channels or down load CDF file if saved.
                    Guys give it a go and let me know how you get on please, hope it works for you.
                    • jig
                      #25
                      Can I ask if you have had any issues since you reflashed in this way?
                      • victor_ray
                        • Oct 2008
                        • 106
                        #26
                        If I leave the box alone without recording anything it goes right through mid night with no problems.
                        I do record things at 11pm which finish at 12pm which then sometimes causes the box to go on stand by after it has finished recording.
                        Try flashing the box as I said and post back if you encounter the same problem.
                        • andy4
                          • 1125
                          #27
                          followed Hi Teck's instructions everything working ok
                          big thanks to Hi Teck & also to satsmo cheers guys
