EuroVox 5000, EuroVox Max - No or Bad Signal
  • chic.
    • 1599
    #31
    Originally posted by brihood
    IM I GLASGOW AND CANT GET ITV OR CHANNEL 4
    AND ALSO SOME DISCOVERY CHANNELS
    Hi m8 thay have moved frequency to 355,000 . 162,000 . and 155,000 .add and scan these or do a full power/deep scan. ps the discovery channels moved to 755,000 last week
    if i helped hit the thanks btn
    • Chrissy_Boy
      • 8
      #32
      Wonder if you can help mate, I had the same problem and tried to reset factory settings and power scan but it brings up nothing whatsoever, when i go back into factory settings it gives me places like birmingham london etc, you any idea what ive done wrong?
      • chic.
        • 1599
        #33
        you may be scanning the wrong symbol rate try 6887 if you dont get any channels then use 6952
        • Chrissy_Boy
          • 8
          #34
          I stay in glasgow and im using the symbol rate 6952 but it doesnt bring anything up, see in the factory settings part there are 11 diffferent options places all over the uk do you know what one i have to select, or have i done something wrong?
          thanks for your help!!
          • msr26
            • Aug 2009
            #35
            Had the same problem..re-flashed it and some channels are back but some still say no signal...
            can someone please get me the latest cdf file for leicester area.... thanks is advance.
            • chic.
              • 1599
              #36
              what box have you got i havent seen one with the options of different places i live in glasgow and my symbol rate is 6887
              • Chrissy_Boy
                • 8
                #37
                Its a eurovox max, my friend has a box and his is 6952 i think thats what mine was, when i click on clear data and then factory default it gives me a list of areas the only one in scotland is TW Edinburgh I have tried powerscanning on it and the signal is crap and locates no channels!!
                • chic.
                  • 1599
                  #38
                  if you go to user installation you should be able to start 155.000 end 755.000 then symbol rate 6887 then press ok
                  • Chrissy_Boy
                    • 8
                    #39
                    if you go to user installation you should be able to enter your symbol rate
                    I can put it in yes, will i do a normal scan and this should pick up the channels?
                    • chic.
                      • 1599
                      #40
                      yes you are to quick for me look at the post above i was editing it when you answered
                      • Chrissy_Boy
                        • 8
                        #41
                        sorry bout that, right ive done it mate thanks very much, ive got the channels but its not got showing me any sky chanells just bbc etc, will check the codes tomorrow.
                        thanks very much for that yer a star.
                        • chic.
                          • 1599
                          #42
                          press menu and on lanuguage settings press ok then type 1968 and enable the last to options .
                          • iceman4u
                            hi people, lost channels in the south east as well, i
                            will try to clear channels and then do a full scan .. will update if it worked
                            • BlueBox
                              • 573
                              #44
                              where in south east?
                              DreamBox 500HD NewEnigma2
                              • NOTTSPAUL
                                #45
                                heres the solution, reset ur box to factory settings from the menu, they rescan for all channels , ALL CHANNELS SHOULD NOW BE BACK BUT THE BOX WONT DECODE THEM, NOW PUT THE UFL_EX5000PVR_24-02-09_DarX UPDATE ONTO YOUR BOX, AND IF BY MAGIC ALL CHANNELS ARE BACK AND UNSCRAMBLED, DO NOT PUT THE UFL_EX5000PVR_24-02-09_DarX UPDATE ON BEFORE SCANNING FOR CHANNELS, hope this helps
