A Konig booster is about the best, but I have found the SLX booster range in Argos to do almost as good a job. They have variable gain also so you can fine tune them.
But to be honest if you signal is too strong a booster will only make it worse and then you will need an attenuator. Before going down this route check all your cabling and connectors are sound, as that could be your problem. Or you may have an external fault at either your external omni box or at the cab, you have been moved down in it.
