help most channels scrambled
  • chrisully
    • 40
    I have lost half my channels says scrambled now sky movied and sky1 2 and 3 and sports 1 2 3 and xtra done a factory reset and done a power scan only found half the channels i had now UFL_EX5100PVR_DarX_16-01-09.exe is what i used to flash tried re flashing and the same can anyone help grrrrrrrrrrrrrrrrrrrrrrrrr
  • Krypton
    • 694
    whereabouts are you mate?
    Khan, you bloodsucker! You're going to have to do your own dirty work now, do you hear me? Do you?
    Chuck Norris has two speeds: Walk and Kill
    There is no "Ctrl" button on Chuck Norris' PC: Chuck Norris Is always in control
    Evolution is a myth. There are only the animals Chuck Norris has allowed to live.
    Chuck Norris does not sleep: He waits
    • chrisully
      • 40
      Oldham greater manchester
      • Krypton
        • 694
        make sure the box is on a direct feed with no splitters and do a deep scan
        • chrisully
          • 40
          then reconnect the splitter because i use for the internet but u mean just use directly wile scanning. should i buy a signal booster i have seen them on e bay?
          many thanks chris
          • Krypton
            • 694
            yeah use direct feed for scanning the reconnect. see if that helps, but wait before you buy a booster, one of the eurovox boys will be on soon mate and may have another solution if my advice doesnt work
            • chrisully
              • 40
              its scanned and picked up everything just plugged back to splitter any trouble ill comment back on this thread. my dad has a booster and no signal trouble but i seem to have may need one i think
              • chrisully
                • 40
                its gone back to crap again now worked at first now no or bad signal or scrambled or stuttering pic think ill get a booster does any one know where best place and make to get
                • chrisully
                  • 40
                  • Krypton
                    • 694
                    go on fleadbay and search for konig booster mate. you want the yellow brick booster. bit more expensive than others, but a lot better
                    • Hob
                      • 240
                      You only lose about 5% quality when using a splitter. If you had all the channels on the single feed then you lost them when using the splitter your splitter may be duff. Try a new splitter first.
                      • rabarber
                        • 18
                        Help for a (rather real stupid) laywoman in Dublin:
                        Having a Eurovox box (and not a Dreambox) I think I joined the wrong forum today. I lost all my sky-channels and understood (with my laywoman-brains) from the Dream-box forum that UPC is 'closing' the entrance to these channels. The guys there spoke of a certain kryptview? But, what the heck is that?
                        Can a laywoman like me do something with it? And if so, what does she have to do with it and where can she get the thing?
                        Otherwise, be honest: Would you advise me not to start with these technical things? Or won't it be as bad as I fear?
                        • satsmo
                          • 6397
                          I have already answered you on your last post http://www.digital-kaos.co.uk/forums...94/index2.html
