Eurovox making loud buzzing noises when changing channels etc
  • Leedufc89
    • Mar 2009
    • 27
    Hello all i was just wonderign if anyone knew any answers to this problem.
    Whenever i change channels on my eurovox its making a loud buzzing noice but obv u cannot hear it much when you are watching a channel but u can hear it well when u are changing them.
    Any ideas of what the problem might be?
  • badapple
    • 2041
    Had same problem with Eurovox Max V.
    I re- flashed box several times before it fixed this problem.
    SLOWLY, OUR FREEDOM IS BEING ERASED.
    SOON, WE WILL JUST BE A NUMBER.
    IF WE DON'T FOLLOW, WE WILL BE ERASED.
    • jckw
      • 760
      do a factory reset m8 that should sort it or check ur scart leads aswell
      we are all learning each day
      • greg_f
        • 32
        Hi lads.
        no need to flash the box yet but jckw prob right with scart leads what it sounds like to me is that you have the sound set to low on your box and too high on your tv,just re-adjust your box to full (right key next to the ok button) and lower your tv vol this should sort out prob also do the same if looped to hi fi make sure vol up full on box and adjust on tv only
        hope this works
        greg
