no sky 1 2 3 on eurovox max
  • bovis31
    • 5
    got no sky 1 2 3 on my eurovox max v done power scan and updated firmware if any one can tell me how to get them i would be very grateful
  • wilf
    • 1618
    try doing a deepscan m8 but first remove any splitters you may have
    • bovis31
      • 5
      spliters
      do the spliters make a diffrence? m8 got all proper spliters and cable vm use uncle works for them???
      • wilf
        • 1618
        bet he sold you the set up too .yes it does make a difference you can put them back afterwards but you have a better chance of getting your channels without splitters, try with if you want but as the deepscan takes a while you may aswell do it right first off
        • bovis31
          • 5
          ha ha no mate
          • wilf
            • 1618
            if you unsure of any scan setting all the advise in here m8
            • bovis31
              • 5
              tried that mate didnt work never mind got the rest k
              • wilf
                • 1618
                worth a try keep checking this post m8 someone will have a solution its just a case of them coming on to read whats already been said
                • smoggy
                  • Apr 2009
                  • 12774
                  you could try adding the frequencies and do a manual scan of them
                  if you say where you are from someone may be able to tell you what frequency those channels are on
                  • chic.
                    • 1599
                    have alook at the channals that say tvch 1,2 exc
                    if i helped hit the thanks btn
                    • camelv
                      • 1202
                      try a factory reset m8 then power scan.
                      its the stuff we think we know that stops us all from learning
