Missing Channels
  • Stu-B
    Missing Channels
    hi i've just got a Eurovox EX1000 SL but i am missin sum channels like Sky 1, Sky Movies Screen 1 & 2 and a few others.
    i have tryed doin a Fast Install & Deep Scan but still with no joy.
    could any1 please tell me why i cant receive these channels
    thanx for any help
  • badapple
    • 2041
    Hi m8, before scanning, do a clear date/factory reset.
    Also scan from direct line without any splitters.
    SLOWLY, OUR FREEDOM IS BEING ERASED.
    SOON, WE WILL JUST BE A NUMBER.
    IF WE DON'T FOLLOW, WE WILL BE ERASED.
    • Stu-B
      just tried that m8 n stillno joy with it
      • master-q
        • 11
        i have a 5000, after a deep scan, i found sky1/2/3 at the bottom of one of the other favorities, others i think
        • Stu-B
          i've tried deep scan but still no sky 1. i think i must have a weak signal coz on sum freqs im only gettin about 30% signal and others freqs are around 83%
          • EAMO 2
            • 1201
            Please state location, if it's Dublin IRL you need manual scan 150.000 MHz
            If in UK weak signal could be caused by bad cables or splitter.
            • Stu-B
              uk. if i have a weak signal is it worth me getting a signal booster
              • EAMO 2
                • 1201
                I don't like boosters. Your cable company should rectify a weak signal issue,
                providing you are paying them. If not you could borrow a booster to try it. If it
                does the trick, then buy a decent one.Most times it's faulty cables or fittings
                that cause poor signal. I sorted out a Kryptvu the other day. None of the
                chls. on 3 highest had a signal, all other chls. were fine. I replaced a dodgy
                cable in the attic & all chls. are fine now.So check your cables.
                You could scan your box in a nearby house on same provider.
                Check all chls. there & then check again in your own house
                • Stu-B
                  checked all cables and connectors n they r fine. looks like a weak signal to me. ta for all ur help though
