thebox
  • thehornets
    • 36
    thebox
    my mate needs some help..i have a blue eurovox but he has just brought something called "thebox". All the channels are still srammbled and i dont think there is any software in it, can someone point me in the right direction
  • deni.babe
    • Aug 2009
    • 13
    hi mate,press menu go to system infomation and see what APP you have it may be dated ,usually when its scrambled you need to switch the EMU ON then go on set default key and press ok and exit then put onto sly sports it should update ,you do this by pressing the menu button then press 1570 this will open a new screen ,if it doesn't update then you need to put codes in manually by again pressing 1570 then nagravision ,before trying any of this do a powerscan first as a lot of people are buying these boxes from ireland,good luk
    • chic.
      • 1599
      Hi m8 the box is a starview go here and ask you will get more help Starview
      if i helped hit the thanks btn
