help with scanning for ex 1100
  • tyson36
    • Aug 2009
    • 115
    im in leeds and cant get any channels! nothing have tried fast and deep scans and get nothing....my v box works fine tho?
  • chic.
    • 1599
    are you using the right symbol rate
    if i helped hit the thanks btn
    • tyson36
      • Aug 2009
      • 115
      i have tried both options...no joy
      • chic.
        • 1599
        "cant get any channels! nothing" so you dont get any fta channels make sure you have put the feed in the rf in not ant its very easy to make the mistake i know i have done it
        • tyson36
          • Aug 2009
          • 115
          yeah its in the rf in, im getting signal quality 0.... but when i try my vbox and broadband they are fine!
          • shrijit
            hi turn on and off with remot and than try to scan. work for me. thanks
            • Reddog622
              • Jun 2009
              • 88
              Might sound a daft question but did you open the firmware with winrar and then do a deep scan?
              Red
              • tyson36
                • Aug 2009
                • 115
                it gets nothing not even fta! the signal quality is 0....but my vbox and broadband work fine. Im thinking it is an rf adaptor problem.
                • satsmo
                  • 6397
                  Take away any splitters and try it from the same feed as your Vbox.
                  • tyson36
                    • Aug 2009
                    • 115
                    yeah did that aswell...no joy
                    • satsmo
                      • 6397
                      Sounds like a tuner or PSU fault. Ask your supplier to replace it. I would try it at a friends house beforehand to rule out a cable fault at your end.
                      • tyson36
                        • Aug 2009
                        • 115
                        yeah will do.....im gutted was well looking forward to using it!
                        • lickledan
                          • 18
                          I BOUGHT BRAND NEW EUROVOX SAME AS YOURS EXACTLY SAME PROBLEM AS U, SPENT 3 HOURS TRYING TO SORT. EMAILED GUY I BOUGHT IT FROM AND TOOK IT BACK, PLUGGED IN NEW BOX WORKED STRAIGHT AWAY
