naw m8y everything is were it shouldbe including the cable im afraid im still sitting here with 4 zeros because when i doonloaded the software it even took away ma council telly as well
eurovox manual install keys
wot u lost your feed to the other box in your house ??any information provided is for educational/experimental purposes only.Comment
Codes for EX NTL in Portsmouth area
Hi Guys,
I am having trouble with updating the keys. I have a eurovox 500 and have all the latest firmware etc, and last night I downloaded the new keys from this forum. I think i should be using the pure codes, is this right??
Also, do I need to update both codes or just one, as the pure codes have two lines, do these both need to be entered?
I tried doing all this last night and still no joy! Can someone please confirm if I am doing the right thing or not? I'm editing the top two lines of the codes at the mo!
Hope someone can come up with new firmware soon!
Cheers
chinkoblinko!Comment
the easist way to do it is by pressing menu button then the yellow button once you do this you should see were you need to enter the keys that are in the keymaster.exe
best to check which keeys you need and the provider key to find this out you could try
1. Press Menu, press OK on language settings.
2. press down
3. Press 1968
you will see the provider key and the name which should help inditfying what keys you need to enterLast edited by pv1; 28 November, 2008, 17:53.Comment
Apologies for being a numpty, complete novice with eurovox500pvr -not got a clue about these keys. can someone post a step by step guide.
Apologies again
Boing BoingComment
