Hi all I am new to these forums so here goes I recently used the latest blue box uploader all went well so I thought today I had the code updating on my box again cant see where I went wrong??
newbie help
is the emu turned on and have you left it on ss1.
the 10/4 sw was the first update after the changes and the key update roll was slower hence the 14/4 update that improved this just make sure that you install the correct sw for your box if any doubt as to if its a gen box or clone box install the clonesafe version
also it always makes sence to do a factory reset both b4 and after installing sw.Comment
That is a Eurovox. If you are talking about the Max V latest was the 28/04/08but only recommended for boxes with a 8% signal problem. Recommended firmware to use for a Max V is dated 18/04/08.I refuse to answer that question on the grounds that I don't know the answer. - Douglas AdamsComment
