eurovox setup problems!
  • danb07
    • Aug 2008
    • 18
    hi guys girls... I am trying to set my box up! all hooked up! done a powerscan and found all of the channels! However the non freeview ones are all scrambled... i need to connect to laptop to download firmware to box.. but i just cant connect! any ideas? does box need to be off? etc... or is there any other way of unscrambling? cheers
  • Digger
    • 154
    you need to connect to your loaptop with a null modem cable and upload the firmware to the box and then scan the box again
    • danb07
      • Aug 2008
      • 18
      yeah I am hooked up with all the right equipment... My box is on and I am watching tv! If I were to plug in now.. all i get is new hardware found and thats it... tries to install and then fails... its a null cable connected to a usb... Iam lost!!
      • Digger
        • 154
        well it must be the wrong firmware your usin as there r red and blue boxs so ya must check which box you have, there maybe a fault with your usb adapter as they r known to be tempermental...
        • biffo1
          • 420
          also put ur box on stand by is it blue/red euro box fw , 2007 2008 model
          [CENTERsigpic[/CENTER]
          • halau
            • Aug 2008
            • 278
            sounds like an issue with the usb and null conection, do a search for the right driver for the usb unit
            • thekid888
              • Oct 2008
              • 14
              You need to use a null modem cable mate direct to your PC ... It wont work through a serial cable and as most laptops dont come equiped with com ports yow will need to use a home computer and go through the port on your hard drive .. I was weeks figuring that out .. Trust me it will work!!!!!!
