eurovox help
  • lilik256
    • Aug 2008
    • 61
    eurovox help
    i got the eurovox put the new firmware on it and i got most channels but i was missing a few for example skysports xtra and skymovies premier im new to this so im not sure what to do is there a code or a search that i can do to get them?
  • satsmo
    • 6397
    Need to know your area and provider info.
    • lilik256
      • Aug 2008
      • 61
      im on vm and im in london shall i get more specific on where i live
      • satsmo
        • 6397
        Without going into full details just tell me what area of London. As I need to verify what ex provider you are on and what TPs are used in your area. A simple powerscan may do the job though.
        • lilik256
          • Aug 2008
          • 61
          i live in south west london how do i do a power scan and what does it do
          • satsmo
            • 6397
            A powerscan will find all the TPs, (frequencies) on your providers network. Press menu, installation, user installation, and you will see a list of frequencies. You will see your symbol rate it will either be 6952 or 6887. Should be 6952 as its an ex TW area. Just tell me which one and we can go from there. Also what firmware are you using. Press menu, config and system info and post what it says for SW revision.
            BTW you must have scanned if you already have channels or did you get this box pre set.
            • lilik256
              • Aug 2008
              • 61
              i have 6952 and with the sw revision 1.0 st4 jul 15 2008 and when i bought the box i did scan.
              • satsmo
                • 6397
                Well thats a powerscan. You should have 34 TPs, (frequencies), can you see 491000 as one of them in user installation. When you done the scan did you do it from the direct feed, i.e. no splitter.
                • lilik256
                  • Aug 2008
                  • 61
                  i have 32 frequencies i havent got 491000 as one of them and i am using a direct feed.
                  • satsmo
                    • 6397
                    Go to menu- installation-user installation-ch edit(green button)add(red button)frequency-491.000-symbol rate 6887-press ok exit once press ok on the frequency you have just added ,then press manual scan.
                    • lilik256
                      • Aug 2008
                      • 61
                      it is searching now how long will this take and what channels will this get me
                      • satsmo
                        • 6397
                        A minute and the ones you are missing hopefully.
                        • lilik256
                          • Aug 2008
                          • 61
                          if it takes longer than 1 minute what does that mean
                          • satsmo
                            • 6397
                            It should find channels if the TP is valid, which that one is for you area and provider. If you are having problems it could be due to a weak signal input. I can give you a CDF for your area and provider if you like.
                            • lilik256
                              • Aug 2008
                              • 61
                              it might be a weak signal due to the bar being red and not going beyond 20% what will the cdf file do and how will it help me
