cdf files ????
  • newboyhere
    • 40
    cdf files ????
    has any one got a cdf file so i can get
    ch 1 ......bbc 1
    ch 2 ......bbc 2
    ch 3 ......stv
    ch 4 ......ch4
    ch 5 ......five
    with all the movies.musci, education cannels in sot of order ?
    etc etc etc etc
  • chic.
    • 1599
    ch 1 ......bbc 1
    ch 2 ......bbc 2
    ch 3 ......stv
    ch 4 ......ch4
    ch 5 ......five
    etc etc etc etc
    yes you will find mine in downloads
    if i helped hit the thanks btn
    • newboyhere
      • 40
      ?? UPDATE
      if i do a flash on my max v
      and install your cdf file chic ....will this also take into account that STV,CH4 etc have been lost ?
      i have done a powerscan ,,,,,they are back on but all over the place !
      • chic.
        • 1599
        no thay just moved today my cdf is a week old but you can add the frequency's 355,000 . 162,000 . and 155,000. scan these frequency's and get all the channels that moved today . thats what i did its mutch better than redoing all the favs again . thay might move more tomorrow
        • kq501
          • 23
          Hi Chic, could you help a fellow hoops fan... I've lost several channels like most folk... never used a cdf file tho... and I'm having trouble downloading the Glasgow one available (keeps logging me out).
          Are you able to send it to me if it's a small enough file, plus could you tell me how to use it?
          • chic.
            • 1599
            cdf
            this is mine give it a try connect your box to your pc with a null modem cable use the ufl you used to flash your box click browse to where you have saved the cdf and load it then press the bottom download
            • kq501
              • 23
              thanks chic
              • kq501
                • 23
                Sorry... will this work on the ev max. I've got the right ulf, but it wont download to machine???
                • chic.
                  • 1599
                  yes it should work ok
                  • chic.
                    • 1599
                    re cdf
                    use this to flash the cdf to the box
                    • kq501
                      • 23
                      It worked Chic... wire must have came a little loose from PC. After i fiddled around with it, it accpeted it.
                      Cheers for the effort you put in. Far better than any I've ever had!!!
                      • kq501
                        • 23
                        Didn't have the channels that went awol the other night.
                        I'm gonna do a factory default, then deepscan (would I have had to update firmware before deep scan?)
                        • chic.
                          • 1599
                          these are the freq's that changed put them in manualy then do a channel update 355,000. 162,000. 155,000.
                          • kq501
                            • 23
                            Chic, I had already started a deep scan on 6952.
                            Once done, if I haven't got the channels back... how do I put these 3 frequencies in manually? Sorry, it's prob basic to a 3 yr old, but I'm clueless with these things?
                            • chic.
                              • 1599
                              menu>installation>user installation>channel edit>red btn add then enter the frequancy then the symbol rate then ok to save.
