lost channels on Eurovox Teesside
  • smoggy
    replied
    Originally posted by hibs11
    hi
    just lost all my movies and espn channels on my eurovox have done a power scan but still not back can anyone help
    by your name I assume you are in Edinburgh, if so nagra 3 has hit you and it will not be long before you have lost all except 1 to 5
    Leave a comment:
  • daz24c
    replied
    hi
    Are you in teesside?
    Espn is 700,000
    movies are 724,000
    Leave a comment:
  • hibs11
    replied
    channels lost
    hi
    Leave a comment:
  • daz24c
    replied
    Originally posted by majy
    I've done a couple of power scans but am not getting sky sports 2 back. Can anyone suggest anything for me?
    sky sports 2 is on 155000 in teeside do a manual scan of that frequency and it will pick it up
    Leave a comment:
  • majy
    replied
    Sky sports 2 Teesside
    Leave a comment:
  • nukeman62
    replied
    Channels back
    Thanks Guys
    Done a factory reset and power scan, all channels back up and running after doing a quick favorites sort everything is now fine.
    Thanks again for all the advice.
    Leave a comment:
  • thered
    replied
    Originally posted by puzzled2
    does anyone have a step by step guide on how you change the frequency manually for sky sports 1 & 3 please
    press
    menu-installation-user installation-your code prob (0000)-red button to update channels
    Leave a comment:
  • puzzled2
    replied
    Leave a comment:
  • STOCKTONDAVE
    replied
    Just joined and having same probs with sky sports 1& 3 and a few others. Tried factory reset & scan but lost channels that said no signal. Will try earlier suggestions - Cheers
    Leave a comment:
  • nukeman62
    replied
    Hi Guys
    Am new today, have lost quite a few channels since last week, thanks for all the info, I am going to try & get the channels back tonight to keep the daughter & misses happy. From Hartlepool and have a Max V 2008
    Cheers
    Leave a comment:
  • villakiller
    replied
    if vm go with n3 surly that will kill them coz every1 will just ~~~~ off to sly or am i just thick
    Leave a comment:
  • pwilkinson
    replied
    Thank you Fergal but I finally managed to do it!!! I had not flashed by eurovox correctly. I had another file on my usb stick and I think it interfered with it.
    For anyone else having probs, I found a really helpful thread by Bad Apple, I have pasted it below (not sure if I am allowed to do that by not sure how to get his or her permission, so I apologise if this causes offense but it was very very useful, so thank you Bad Apple!!)
    Hi m8, here is the firmware for your box Digital Kaos - Downloads - EX1100 Sept25th Beta Firmware
    Heres a guide and make sure the USB pen is formatted to FAT32 first.
    Use winrar to extract/unrar the abs file needed to flash your box then.....
    1). To update the firmware on the box follow below
    2) place the usb pen drive into the eurovox,(with the power to the box off) power the box on.
    3) Menu.........record......HDD FORMAT...format the usb flash drive..Power the box off and remove the usb flash drive.
    4)Place the usb flash drive into the pc and drag and drop the updated beta abs file to its folder.
    5)With the power to the eurovox off and all set up on the tv ready to view....Place the usb flash drive into the eurovox and power the box up.
    6)menu......TOOLS.......UPGRADE BY USB.....SW..THEN RED BUTTON TO START THE UPGRADE...you'll see a bar move across the screen and the box will reboot..Job done..
    REMEMBER,ALWAYS POWER THE BOX DOWN B4 REMOVING/INSERTING THE USB FLASH STICK TO AVOID COSTLY ERRORS.
    SCANNING.
    MENU.........INSTALL..........POWER-SCAN.....AND START THE SCAN...
    __________________
    ALL THANKS TO BAD APPLE
    Leave a comment:
  • Fergal
    replied
    Press ok on language so you see english then type 1968 twice using the numbers on the remote it should show you a hidden menu
    what box is it and what firmware did you flash on
    Leave a comment:
  • pwilkinson
    replied
    I went onto language settings and it does not give the option to type in numbers but I tried anyway and did not get anywhere.
    Really sorry but you might have to baby walk me through it, this sort of thing is not my forte as you may have already guessed!!
    thank you in advance
    Leave a comment:
  • Fergal
    replied
    Originally posted by ryanjohns
    hello been to factory reset and then done the powerscan but still no luck where is it that you put the frequency figures in on euro vox max
    You can manually add frequencys in the installation menu
    Originally posted by pwilkinson
    Sorry for jumping in on this but I am in Stockton On Tees setting up a new box and most of my channels have $ sign in front of them and therefore scrambles. I have reformatted my usb to fat32 I have tried 2 different firmware and I am doing a deep scan on 6887. If anyone has any ideas where I am going wrong it would be greatly appreciated!
    Press menu,press ok on language then type 1968 twice press default key and turn emu on and exit out and change to a blank channel and wait 5 mins
    Leave a comment:
