help
  • philgixer
    • Sep 2009
    • 12
    help
    hi lost all me chanels on me eurovox max v....... iam in warrington ive heard they have changed the frequency, can somebody help. done power scan and not worked pls help
  • chic.
    • 1599
    factory reset delete all channels then do a power scan on the symbol rate for your area 6887 or 6952.
    if i helped hit the thanks btn
    • philgixer
      • Sep 2009
      • 12
      already tryed that on both different symbol rates and its not worked. also re downloaded all the channels off my computer, by plugging into my comp and loaded the filmware on again. and still not working. a bit stumped here fellas...... my kids have also changed the password on the eurovox and i carnt do a factory reset with out the code. and ideas ??????
      • chic.
        • 1599
        try 1004 or 1007 for the pin
        • philgixer
          • Sep 2009
          • 12
          hi thanks. the code 1004 works done a factory reset now. and searching for the chanels now... fingers crossed. thanks.
          • philgixer
            • Sep 2009
            • 12
            help
            hi guys. ive done a factory reset and power scan ive now got about 200 channels, missing all my sports and itv and channel 4 ect.... all bbc.... i changed the symbol rate and it sort of worked. gettin very peeeeeed off now....... how do i change the symbol rates.... and why have i not got all me channels back. cheers fellas
            • Fergal
              • Aug 2008
              • 1007
              have you re enabled the emu press menu,language and type 1968 twice and turn the emu on .
              • philgixer
                • Sep 2009
                • 12
                aaaaarrrrrrrrrrrrrrr iam bloody sick of this now. lost all me channels again. can only get discovery, and the test channels. ive done fast scan deep scan on all different symbol rates. gettin very annoyed now. think this might go through the window. and done the 1968 and enable is already on. any one any ideas in warrington if this helps
                • philgixer
                  • Sep 2009
                  • 12
                  OMG OMG OMG IVE DONE IT....... SYBOL RATE 9.887 HOPE THIS HELPS SOME PEOPLE.... IVE GOT A SPLITTER INTO MY TV AND COMP... JUST PUT THE CABLE IN YOUR BOX SO U HAVE A DIRECT FEED, JOB DONE.... EASY WHEN U NO HOW... CHEERS FOR ALL YOUR HELP BOFFINS......
