Digivox T edit PID's
  • philly
    • 119
    Hi all,
    Anyone know how to (if possible) edit audio PID on the DigivoxT
    box.
    Philly
  • cactikid
    • 12017
    do you mean to press the audio button and select a different stream or what.
    • philly
      • 119
      no sound
      I need to change the audio PID which I presume is the ID for he
      audio stream. The boxT allows you to see the Audio, video and PCR (PID's) under its edit menu and adjust if necessary. I need to make changes to these settings on my DigivoxT as I have lost sound on two or three channels.
      Any Ideas.
      Thanks,
      Philly
      • cactikid
        • 12017
        sometimes a factory reset 0000 to delete ,power on antenna auto scan and emu on,also press the set default key and exit out to update.
        menu-system info-ok1004-key emu to on.
        • philly
          • 119
          DigivoxT sound prob.
          Thanks for that.
          Factory default worked fine. I will re-install my channel plan now that I have sound back.
          Many thanks.
          Philly.
          • cactikid
            • 12017
            well done m8 usual fix to try
            • philly
              • 119
              Hi Cactikid,
              I am now looking for jam on both sides of the bread, (or give the devil an inch and he will take a yard).
              Defaulting the box restores sound but when I re-install my original channel plan from my PC I loose sound again. Any way to
              get around this as sorting out a new channel plan manually is a bit of a pain.
              Philly (in lazy mode).
              • cactikid
                • 12017
                if you have a channel file on pc its no good as settings have changed and dump files are no good,have you done another factory reset and rescan provider and emu to on.by moving any file on pc to trash that has a dump channel list you will find the one you will upload to pc sort out and then download ch.data file.
                what flavour jam
                • philly
                  • 119
                  channel plan sort
                  Sorry if I appear silly but what do you mean by a 'dump' file.
                  My backround is in electronic repairs (allmost 30 years) long before PC's became the norm but I am still willing to learn.
                  Philly
                  • cactikid
                    • 12017
                    when you scan your box you get get a load of channels in wrong place,never bothered me you can upload them to pc and use starview editor to put channels in your preference back to box by download.when you upload to pc i call it a dump file and if you had 20 boxes you could download the dump file to all boxes,saves you scanning all boxes,dump files dont last long if frequency changes any channels then file is binned in trash and start again.
                    • philly
                      • 119
                      digivox T channel plan.
                      Thanks.
                      I didn't realise that there was an starview editor available.
                      Can you point me in the right direction to download this.
                      It sounds like an easier task than doing it on the receiver first and then saving it to your PC.
                      Thanks again,
                      Philly.
                      • cactikid
                        • 12017
                        never used it so no idea has a tut .
                        Digital Kaos - Downloads - Starview Channel Editor + Instructions
                        • philly
                          • 119
                          digivox channel plan
                          Hi cactikid,
                          Thanks a lot for the info. I installed the starview editor and it works fine. My 10 year old sorted out a new channel plan by simply drag and drop. It works for both the BoxT and the digivox T, however the channel plans for both boxes are not interchangeable.
                          P.S.
                          If you ever experience intermittent trouble with these boxes during boot up look out for dry joints on IC U10. Have had this on two ocassions recently. You need a needle point soldering iron and a microscope. A steady hand is also an advantage.
                          Don't try this the morning after the night before.
                          Philly
                          • cactikid
                            • 12017
                            no cable box here working on n3 since august .
