help please
  • rosman
    help please
    hi there. could someone helps please
    i've just got eurovox tx 2008
    loaded latest software on it. software version evx tx_h_071123.
    it seems to have loaded ok. but do i have to acess secret menu to
    turn on emu. ect. and if so how do i do this.
    would be greatfull if anyone can help
    thanks rosman.
  • thered
    • Aug 2008
    • 4915
    not familiar with your box but when you search for your channels you just need to input the freq for your area either 6.887 or 6.952 in the settings b4 you scan as far as i know eurovox if flashed correctly is all ready to go
    • satsmo
      • 6397
      The TX is for Chorus MMDS and has a default symbol rate of 6875. Emu is also on by default if firmware is flashed correctly.
      • hopper28
        • 119
        Also got my hands on the same box, reflashed last night and did a system reset, then rescaned, first time only scanned 5%. Turned it off and did a reset again and rescaned fully, went to a channel updating came up and all working fine here in the south.
        • rosman
          hi again. and thanks for your replys
          my problem was i scanned channels first then put on software
          and nothin would open.
          so i had to do a system reset and scan again.
          now all working fine in the midwest of ireland.
