Eurovox Max Blue Flashing Probs
  • poolieblue
    • 8
    hi ive just flashed my old eurovox max blue like i have dun 100's of times but now i cant get any joy out of it....theres nothin comin on the screen...any ideas wat ive dun wrong??????
  • marshallar
    • 107
    is there anything on the ev's display?
    • poolieblue
      • 8
      it just says ooo1 on the display but nothing comes on the screen...is it goosed then?
      • camelv
        • 1202
        open it up m8 and check the psu board to see if any of the capacitors are leaking or swollen.Digital Kaos - Downloads - c14 capacitor replacement
        its the stuff we think we know that stops us all from learning
        • chic.
          • 1599
          while you have the top of press the small black micro btn on the main board its to the right centre looking from the front
          if i helped hit the thanks btn
          • poolieblue
            • 8
            well pressing the black button gets at least summit outta the box and i can change channels at least but as soon as i try to use the remote it just freezes on me agin
            • smoggy
              • Apr 2009
              • 12804
              sometimes flashing with the wrong firmware (you may have a clone) can cause the loss of the scart output and you finish up with a number displaying and the remote appears not to work, if this is the case try this procedure.
              disconnect your scart
              connect some coax cable from the TV / VCR socket of the eurovox to the TV.
              tune your telly to the VCR channel where you will get the 'enter pin' screen.
              using your remote enter the master pin which is 1004.
              go to menu and clear data, then do a factory reset.
              plug your scart back in and do a powerscan as normal or reflash the box with the clonesafe firmware
              • poolieblue
                • 8
                smoggy ur a F***in star mate that worked a treat and gave my old box the kiss of life...thanx a million mate
                • smoggy
                  • Apr 2009
                  • 12804
                  your welcome, good to see your sorted
