connecting hardrive to pc via external case
  • big-g
    • 80
    hello everybody, can anyone tell me how to transfer data off my hardrive of my eurovox ex500 i have put it in my external case but what do i do next?
    If at first you don't succeed,
    destroy all evidence that you even tried.
  • caveman_nige
    • Feb 2008
    • 4920
    Are you using windows or linux on your pc? Can you you see the external drive on your PC?
    • big-g
      • 80
      im using vista cant see drive in my computer when i go to computer management what do i do? i tryed it already and lost all things on hardrive when i plugged it back in to eurovox dont even know how i did it because i didnt format it,i dont really want to do it again until i know how to do it properly because i dont want to risk eurovox rejecting it,does the hardrive have any drivers or anything on it? cheers BIG G
      • satsmo
        • 6397
        You cannot transfer recordings between the EV and a PC. It will just format the drive and you will lose all recordings.
        • big-g
          • 80
          thats not good any ideas of the best way to get things off it?
          • satsmo
            • 6397
            Bit of a oversight as you say and not exactly what it was advertised as. You can transfer recordings from EX5000 to EX5000 but as you said that isnt what you and others want.
            As its a closed source box the type of format the EX use is not known. Linux based I would assume but even when used on a linux based PC it will still do the same thing and you will lose all your recordings.
            The developers are aware of this but this hasn't been looked at to my knowledge.
            • ITS A SCAM !
              • Oct 2008
              • 1140
              Maybe there is a problem with your hard drive enclosure ?? I shall be getting a USB to IDE adaptor to transfer programmes from my hard drive....look at ebay item number 280231462402 This will do you fine, also it can be used for testing other pieces of hardware that require a 2.5" or 3.5" IDE connection...
              • satsmo
                • 6397
                As said its not the drive its a development issue.
                • ITS A SCAM !
                  • Oct 2008
                  • 1140
                  i am confused.......what exacly is the problem then ????? You must be looking at the problem differently then me so is it not possible to connect the hard drive to a pc ????
                  • caveman_nige
                    • Feb 2008
                    • 4920
                    Well thats useful to know, although i don't have one of these boxes but a couple of mates have them. I was heading towards viewing them via a linux os but as satsmo has advised with the above it would have been a nasty dead end..
                    • ITS A SCAM !
                      • Oct 2008
                      • 1140
                      so eurovox are using their own format ????? Thats not good, i was looking forward to recording Stoke beat Man U on boxing day, so i can burn it to DVD....LOL
                      • big-g
                        • 80
                        i have an external enclosure that is not the problem as soon as you open it up in computer management you lose all recordings on the drive and the pc doesnt even read the drive but never mind you cant have everything for nothing,so if anybody is thinking of trying it dont bother it wont work that way
                        • ITS A SCAM !
                          • Oct 2008
                          • 1140
                          I am sure that i have seen a seller of this model advertising that you can connect it to a pc, so you can upload its files. I think i will try and find it again, and ask them if they have tried it for themselves...and if they did, did it work ??
                          • ITS A SCAM !
                            • Oct 2008
                            • 1140
                            I have taken this from the Rayyonics LTD website, and they recon you can connect the hard drive to a pc
                            "A Unique Design of the Hard Drive Slot on the Front means no Tools are required to Install one.
                            You can remove and share your Hard Drive with others to share your Media Library.
                            You can also connect the Hard Drive to a PC and download your Content To Store or Burn on to DVD.
                            It takes a IDE Laptop Hard Drive between 80gb/120gb giving you 40/60 hours worth of recording."
                            I am very confused
                            • satsmo
                              • 6397
                              As I said its not as it was originally, (and still is), advertised.
