flashing maxv
  • mikmoz
    • 63
    flashing maxv
    after flashing my 1000sl this morning with great success[many thanks again to all involved]i volunteered to flash my mates maxv i downloaded latest firmware and loaded it to his box,all seemed to work as it should until i connected to tv just to check it,it now just says updating codes.is there something i should be doing with a max v that i didnt do with 1000sl?would i have to connect it to his tv for it to work?cheers and thanks again
  • kanut
    • 38
    just done a max v box. updated the firmware
    Had to do a (power scan) fast install to get the channels, but working fine
    • domino21
      Eurobox
      how did you flash it
      • Los Verdiblancos
        • 25
        Is it the same way of flashing as before for the max v ?
        Also can you still save your cdf file & download it back onto the box when flashed ?
        Regards.
        • jenkins83
          yeah same problem here
          • mikmoz
            • 63
            i saved the channels when flashing so didnt think i would have to scan for them again,this worked on 1000sl no problems.maybe i will try power scan, cheers
            • mikmoz
              • 63
              flashed it the same way i did the 1000sl but uses the firmware for maxv.seemed to be pretty much the same procedure,it said download complete,was only when i connected it to tv i got the updating codes.
              • mikmoz
                • 63
                just as i was searching through some of the posts lo and behold the maxv burst into glorious technicolor.so for those of you having the same problem just leave it for 15 mins or so.many many thanks for all the great help and advice.a great forum with some really sound peeps .cheers.
                • casperleo
                  ill try it now cheers.
